We replaced the control panel back in April 2012. It was showing a different code then. After replacing the control panel it has been working fine. Now it is flashing a PF code. We have replaced the control panel again, and it is still flashing the code and oven is not working.
Groups: APP Team
Hi. Did you replace the control panel, or the control board? When you push the OFF key is the control board responds? You may need to replace the control board Part number: 9760013
Thank you. Post the results. Simon.
We replaced the control board today and it is still flashing the PF code.
Groups: APP Team
Hi.
Make sure you connected the flex ribbon to the control board. Are you able to clear the PF for a few seconds?
Simon.
