drum wont turn dryer hums when you push the knob but wont go around :confused:
Can you spin the drum by hand fairly easy?
I can turn it but it seems to rub
Can you identify where the rub noise is coming from? Does it sound like the drum rubbing on the front, sides, rear. If up front, run your hand along the inside between the drum and dryer front for anything like a penny caught between the drum and dryer lip.
I lifted the top and the belt is in tact and on the front side of drum is the rubbing
ok, with the top off, start the dryer and see if the drum tries to turn.
I did that and no it wont turn
You may have a broken roller... Model PYE2300AYWOr something is stuck in the blower wheel located at the lower left. To check further, you will need to remove the front of the dryer and inspect.
how do I know if is broken
