3 Pages123>
Reenie50
#1 Posted : Tuesday, August 19, 2008 8:03:14 AM(UTC)
Reenie50
drum wont turn dryer hums when you push the knob but wont go around
:confused:
Reenie50
#2 Posted : Tuesday, August 19, 2008 8:08:11 AM(UTC)
Reenie50
hello
:confused:
abadfish66
#3 Posted : Tuesday, August 19, 2008 8:18:51 AM(UTC)
abadfish66
Can you spin the drum by hand fairly easy?
Reenie50
#4 Posted : Tuesday, August 19, 2008 8:25:23 AM(UTC)
Reenie50
I can turn it but it seems to rub
abadfish66
#5 Posted : Tuesday, August 19, 2008 8:28:44 AM(UTC)
abadfish66
Can you identify where the rub noise is coming from? Does it sound like the drum rubbing on the front, sides, rear. If up front, run your hand along the inside between the drum and dryer front for anything like a penny caught between the drum and dryer lip.
Reenie50
#6 Posted : Tuesday, August 19, 2008 8:30:39 AM(UTC)
Reenie50
I lifted the top and the belt is in tact and on the front side of drum is the rubbing
abadfish66
#7 Posted : Tuesday, August 19, 2008 8:33:41 AM(UTC)
abadfish66
ok, with the top off, start the dryer and see if the drum tries to turn.
Reenie50
#8 Posted : Tuesday, August 19, 2008 8:34:37 AM(UTC)
Reenie50
I did that and no it wont turn
abadfish66
#9 Posted : Tuesday, August 19, 2008 8:38:48 AM(UTC)
abadfish66
You may have a broken roller...Model PYE2300AYW
Or something is stuck in the blower wheel located at the lower left. To check further, you will need to remove the front of the dryer and inspect.
Reenie50
#10 Posted : Tuesday, August 19, 2008 8:43:32 AM(UTC)
Reenie50
how do I know if is broken
Guest (10)
dryier drum wont turn when clothes are put in, with cloths te dryier will run (Dryer Repair)
by jklimuszka 12/7/2012 3:25:03 AM(UTC)
drum wont turn with a normal load (Dryer Repair)
by fred bruning 4/25/2012 10:42:17 AM(UTC)
LG Front Load-LE Code- Drum wont turn (Washer Repair)
by sleddoc 5/3/2011 5:51:12 AM(UTC)
gas dryer drum wont turn (Dryer Repair)
by mpeccleston 10/24/2010 7:54:23 AM(UTC)
Front Loader drum wont turn (Washer Repair)
by jtoddrn 4/10/2010 8:14:11 AM(UTC)
admiral dryer..drum wont turn (Dryer Repair)
by PJfuture 11/25/2009 6:47:13 AM(UTC)
Drum wont turn (Dryer Repair)
by beachboy 5/5/2009 1:20:56 PM(UTC)
3 Pages123>
