RLC
#1 Posted : Wednesday, November 17, 2010 8:09:01 AM(UTC)
RLC
When knob is pulled out to start a load the tub fills up with water but then it just sits there. There is no noise, no action at all. If I move the knob to spin it will empty the water out but nothing more. I followed the t/s procedures on the tech sheet and everything appears to ck good. But the tech sheet mentions checking the timer line sw but doesnt tell me how to ck it.
#2 Posted : Wednesday, November 17, 2010 4:47:57 PM(UTC)
Perform the troubleshooting as described in the attached file and post the results.
File Attachment(s):
RLC
#3 Posted : Wednesday, November 17, 2010 5:05:50 PM(UTC)
RLC
Gene, Thank you I will do these tests in the morning and report back to you.
Thanks again, Rodney
RLC
#4 Posted : Thursday, November 18, 2010 5:51:52 AM(UTC)
RLC
Gene, the following are the results of the t/s that you instructed me to do.
Resistance between 1/2 2/3 & 3/1 all were 2.8
Voltage between 5/6 was 125
Voltage between 5 and 1,2,6,9,&10 was 0
If as your chart shows I need a new timer how does that knob come off. I have tried everything short of breaking it and I cant seem to get it off. If you cant tell I am not extremley proficiant at the use of a volt meter. When I did the check for the 10 pin voltage I still had the knob set for heavy load and pulled out, was that right? And according to my tech sheet it looks like pin #7is empty, is that correct? There are no loose wires in the area but I just wanted to confim that so I know that I am on the right pins when doing the ck.
ThereTTt
#5 Posted : Thursday, November 18, 2010 4:33:34 PM(UTC)
Rodney,
Your diagnosis looks correct. In order to remove the timer knob push the knob in and turn it CCW.
- The timer Part number: AP3214642
RLC
#6 Posted : Thursday, November 18, 2010 5:08:18 PM(UTC)
RLC
Gene, thanks for your help.
Rodney
#7 Posted : Thursday, November 18, 2010 5:48:15 PM(UTC)
RLC
#8 Posted : Saturday, November 20, 2010 12:57:00 PM(UTC)
RLC
Gene, Help! I changed the timer and it did not fix the washer ( doing the same thing ). However, when I rechecked the voltage readings between 5 and 2,6,10 now I get 120 volts with nearly 0 on 1 & 9. So in other words now it indicates that the speed control is bad.
#9 Posted : Monday, November 22, 2010 1:08:28 PM(UTC)
Rodney,
It is very rare for both such parts to be bad together but it happens.
Try to put the old timer back after you replace the speed control. If it would work and you ordered the timer from Appliance Parts Pros, you still can return it even if it was installed.
- The speed control board Part number: AP3967975
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
Buzzing and not spinning (Washer Repair)
by sweetac100 11/22/2022 2:50:16 PM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Whirlpoool Duet not spinning clothes dry (Washer Repair)
by AdamsBT1 4/9/2022 6:03:49 AM(UTC)
Ge washer tub not spinning (Washer Repair)
by Rconner86 3/17/2022 7:32:41 PM(UTC)
Maytag MTW5770TQ) Draining but not spinning (Washer Repair)
by cj2874 2/6/2022 3:54:15 PM(UTC)
Whirlpool WTW4950xw0 not spinning, draining (Washer Repair)
by webdiva20 12/29/2021 10:43:20 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
