RickWilliams
#1 Posted : Monday, October 25, 2010 11:45:37 AM(UTC)
RickWilliams
We have a gas dryer that stopped heating recently, The igniter heats up but the flame never starts. I'm suspecting one or both coils to be bad but I'm not sure.
Everything still runs it just does not heat.
Any other suggestions would be great.
magician59
#2 Posted : Monday, October 25, 2010 11:55:26 AM(UTC)
magician59
The most common failure is the ignition coils. But other components to consider are the flame sensor and the control board. You can rule out the flame sensor by by-passing it and seeing if you get a flame. If you do, replace the sensor. Here's the part number for the coils.
Part number: AP309425
RickWilliams
#3 Posted : Monday, October 25, 2010 2:23:11 PM(UTC)
RickWilliams
Resolved! It was the coil. I replaced them a it's working as designed.
Thanks for the reply.
magician59
#4 Posted : Monday, October 25, 2010 6:28:33 PM(UTC)
magician59
Well done!
You saved yourself a bunch of money.
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Gas dryer will not heat (Dryer Repair)
by PhilWi 10/19/2012 12:50:42 PM(UTC)
Maytag gas dryer will not heat (Dryer Repair)
by jsweeyor 10/2/2012 12:15:23 PM(UTC)
GE gas dryer will not heat (Dryer Repair)
by kthorson 9/27/2012 4:30:00 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore gas dryer will not heat (Dryer Repair)
by mcclr 10/24/2009 5:51:31 PM(UTC)
by sch8891 10/13/2009 8:26:20 AM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
by Ron S 11/30/2008 1:28:06 PM(UTC)
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 11/22/2007 5:52:59 AM(UTC)
by retcop320 9/11/2007 3:18:41 PM(UTC)
maytag gas dryer will not heat after initial burn (Dryer Repair)
by Agustin 8/27/2007 3:21:24 PM(UTC)
