Al
averona
#1 Posted : Friday, August 1, 2008 6:46:16 PM(UTC)
averona
I have a top load kenmore washer that makes a thumping noise when spinning. I don't know how to open the front panel so I can inspect the drum as it is tilted to the right side. Please help. Thank you. AL
#2 Posted : Saturday, August 2, 2008 1:54:29 AM(UTC)
Go to www.applianceaid.com for info. When apart, check the skate board for misalignment and check for a missing spring, should be three of them.
averona
#3 Posted : Saturday, August 2, 2008 10:22:14 AM(UTC)
averona
Thank you very much for your rapid reply, richappy! My problem is still not knowing how to remove the front of the cabinet to get to the inside. I was unable to find this info anwhere. AL
#4 Posted : Sunday, August 3, 2008 1:43:34 AM(UTC)
Remove agitator and check the drive block, the nut may have come loose.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Savings through Textbook Rentals (General Talk)
by Guest 6/25/2024 4:12:42 AM(UTC)
Digital transformation to move into the future (General Talk)
by Biyen 6/19/2024 12:57:45 PM(UTC)
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Kenmore Elite Commercial#25344723100 (Refrigerator & Freezer Repair)
by Stubblefield 6/13/2024 5:47:53 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Maximizing Savings through Textbook Rentals (General Talk)
by Guest 6/9/2024 10:31:43 PM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
KRMF706EBS01 Door Ajar Alarming (Refrigerator & Freezer Repair)
by Guest 5/24/2024 5:38:21 AM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Natural gas orifices GE range (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/12/2024 2:30:45 PM(UTC)
