weenson49
#1 Posted : Sunday, October 17, 2010 8:28:18 AM(UTC)
weenson49
Freezer is not working at all - refrigerator is cooling but only slightly and intermitently. Checked relay - heard no rattle so we replaced it, cleaned all dust. Still not working.
#2 Posted : Monday, October 18, 2010 4:22:33 AM(UTC)
Replacement parts for ARS91678AB models | AppliancePartsPros.com
I find the above confusing.
Is it not working at all or is it working sometimes?
The refrigerator gets it's cooling from the freezer so the freezer must be running at least partially.
Could you please give a better description on what is happening.
What is running and what is not (compressor, fans etc.)
Here is a good site with fridge troubleshooting info
http://www.applianceaid.com/frig.html
weenson49
#3 Posted : Wednesday, October 20, 2010 8:25:02 AM(UTC)
weenson49
compressor and fan are running. Refrigerator is cool - not cold. Freezer is not working at all.
#4 Posted : Wednesday, October 20, 2010 8:37:34 AM(UTC)
Remove the cover in the freezer and take a look at your evaporator coils.
If there in no frost on them then you are either out of freon or there is a clogged orifice in the sealed system.
To do an actual check you will need a pro with a set of gauges.
If there is frost in one area of the coils (Usually where the freon enters the coils) then you are low on freon.
Note: Make sure the compressor has run for a couple hours as there will be no frost if the unit has just completed a defrost cycle.
You will need a pro to find/fix the leak, evacuate and recharge the freon.
This will not be a cheap fix and it often makes more sense to invest the dollars into a new fridge.
If this unit has been moved on it's side and now will not work, did you let the unit sit for 24 hours before plugging it in?
jrschrock
#5 Posted : Saturday, October 23, 2010 1:12:17 PM(UTC)
jrschrock
Does your water filter work? Is that what's causing the drip? I had to replace mine about 4 months ago and I was having similar problems. I went through **************************.com. I think part number 4396508 would work for you if you do indeed need to replace it. Hope that helps!
weenson49
#6 Posted : Sunday, October 24, 2010 8:50:07 AM(UTC)
weenson49
The compressor comes on for about 3 to 5 seconds - draws electrical power then the overload clicks and the compressor stops. It cycles this way about every 2 minutes.
#7 Posted : Sunday, October 24, 2010 9:37:46 AM(UTC)
Could be the compressor, the start relay of the overload.
Along with the link in my first post here is a good site with info on how to check these.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Amana side by side freezer - freezing intermittently (Refrigerator & Freezer Repair)
by handyandy71 1/6/2017 1:47:27 PM(UTC)
Older Amana side by side replacement thermostat (Refrigerator & Freezer Repair)
by smartyrodriguez 11/15/2016 7:26:55 AM(UTC)
Amana Side by Side not cooling (Refrigerator & Freezer Repair)
by craig72 10/18/2016 3:52:51 PM(UTC)
Amana side by side not cooling but compressor running (Refrigerator & Freezer Repair)
by steelers1 10/7/2014 7:33:52 PM(UTC)
Amana Side by Side Ice Buildup and Leaking (Refrigerator & Freezer Repair)
by LavaPit 8/25/2014 10:13:44 AM(UTC)
amana side by side not defosting (Refrigerator & Freezer Repair)
by jojowil 7/20/2014 5:45:20 AM(UTC)
amana side by side 20 degree freezer temps (Refrigerator & Freezer Repair)
by jdh022764 7/14/2014 7:55:37 PM(UTC)
Amana side by side not freezing (Refrigerator & Freezer Repair)
by mjp0074 8/27/2013 12:25:14 PM(UTC)
Amana side by side freezer not staying frozen (Refrigerator & Freezer Repair)
by hollykasper 8/3/2013 10:24:39 AM(UTC)
Amana side by side isnt cooling well (Refrigerator & Freezer Repair)
by kcruze 6/17/2013 6:27:21 PM(UTC)
Amana Side by Side Ref. (Refrigerator & Freezer Repair)
by sandraandlarry 2/25/2013 1:03:08 PM(UTC)
amana side by side refrigerator water line inside freezer door leaking (Refrigerator & Freezer Repair)
by borth 10/21/2012 9:01:56 AM(UTC)
Amana Side by Side (Refrigerator & Freezer Repair)
by hockey4179 7/29/2012 1:07:35 PM(UTC)
Amana side by side refrigerator side is freezing (Refrigerator & Freezer Repair)
by bsgcjg 10/15/2011 2:16:52 PM(UTC)
Amana side by side stopped cooling properly lastnight (Refrigerator & Freezer Repair)
by dgetty 8/4/2011 4:03:52 PM(UTC)
