Cribbsfamily
#1 Posted : Sunday, October 3, 2010 2:35:40 PM(UTC)
Cribbsfamily
The lights on the contol panel come on and when I press "start" within 2 minutes you can hear the motor running, but no water comes into the dishwasher. Whenever we check the water hose, it is running fine up to the connection at the dishwasher. What could be wrong?
#2 Posted : Sunday, October 3, 2010 4:37:51 PM(UTC)
Check that the overflow float is not stuck in the up position. This switch kills power to the fill valve.
Check that the fill valve is getting 120 volts when the unit should be filling.
If it is getting voltage then either the valve is toast or the filter screen on the input side of the valve is clogged solid. Check/clean the filter screen. Do not permanently remove it from the valve as it is there to keep crud out of the valve. Which could hold it open and cause a flood.
Cribbsfamily
#3 Posted : Monday, October 4, 2010 9:00:44 AM(UTC)
Cribbsfamily
It isn't reading any voltage. Now what?
#4 Posted : Tuesday, October 5, 2010 1:40:14 AM(UTC)
Unplug/remove power from the unit and check the overfill switch. It should be 0 ohms. Could be the switch is broken internally.
If OK, check the wires from the control board to the valve/switch combo.
If they are good, odds are that the control board needs replacing.
whirlpool not getting water in the door dispenser with filter installed (Refrigerator & Freezer Repair)
by jws13 12/25/2020 1:01:34 PM(UTC)
Kitchenaid ice machine not getting water consistently (Refrigerator & Freezer Repair)
by neonot 1/2/2020 9:14:38 AM(UTC)
Ice maker not getting water (Refrigerator & Freezer Repair)
by GLP 11/25/2016 7:19:47 PM(UTC)
by Mike Sasser 9/13/2016 11:25:07 AM(UTC)
Maytag quiet series 100 not getting water inside (Dishwasher Repair)
by softball24 1/9/2015 12:54:27 PM(UTC)
Kitchenaid icemaker not getting water (Refrigerator & Freezer Repair)
by cartmom 9/18/2014 1:21:28 PM(UTC)
by awashko 3/27/2014 8:13:43 AM(UTC)
Not getting water (Dishwasher Repair)
by LDOCHOP 8/12/2013 9:36:09 PM(UTC)
ice maker not getting water (Refrigerator & Freezer Repair)
by jmr82 2/4/2013 10:01:51 PM(UTC)
DW not getting water (Dishwasher Repair)
by digidutch 9/6/2012 1:08:35 PM(UTC)
by markplee@comcast.net 4/23/2012 7:58:24 AM(UTC)
GE not getting water (Dishwasher Repair)
by pdy9880 4/14/2012 3:35:27 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
by redgtfour 2/19/2012 2:00:54 PM(UTC)
ge monogram - ice maker not getting water (Refrigerator & Freezer Repair)
by jmeurer 12/23/2011 8:41:41 PM(UTC)
