My icemaker is not getting water, hence not making ice cubes.
The water dispensor in the freezer door is working. Today I defrosted the freezer and the ice tray is still not getting water.
Ideas?
Originally Posted by: jmeurer  My icemaker is not getting water, hence not making ice cubes.
Ideas? Hi JMeurer, Were you able to solve the problem? I've facing the same sympthoms today. Thank you, XtremeRob
Ideas? Yes, I fixed it and it works fine now. I needed to replace the Water Solenoid Inlet Valve. It was located under the fridge and easily accessible. Before replacing I went to Youtube to watch a video on how to test a solenoid. Ordered a new one online and took me 15 minutes to switch-out. Had to adjust the water flow screw on the icemaker because the new solenoid was overfilling my ice tray. The part I replaced: Universal Refrigerator Replacement Water Solenoid Inlet Valve WR57X10051
