Mike Sasser
#1 Posted : Tuesday, September 13, 2016 11:25:07 AM(UTC)
Mike Sasser
I checked water pressure to inlet valve all good,but no water from valve to ice maker. Unplugged power source,unplugged valve and did a continuity test on valve. Digital meter read 193 manufacturer says should be between 500 and 1500, does that mean the inlet valve is bad?
cbmserviceguy
#2 Posted : Wednesday, September 14, 2016 10:36:18 AM(UTC)
cbmserviceguy
I would say it's at the least very suspect. Have you forced a harvest cycle and checked for voltage at the valve?
Mike Sasser
#3 Posted : Wednesday, September 14, 2016 11:36:07 AM(UTC)
Mike Sasser
No,how do you force a cycle?
cbmserviceguy
#4 Posted : Wednesday, September 14, 2016 11:49:05 AM(UTC)
cbmserviceguy
Depends on the age. Typically W/P you pop the front cover off the ice maker and put a jumper wire between T and H. After it turns for a bit, pull the wire and it should keep going. Go around back and watch the meter for a few second flash of 120vac. Get the meter set up and connected to the valve plug before you jump it.
Ice maker not getting water (Refrigerator & Freezer Repair)
by GLP 11/25/2016 7:19:47 PM(UTC)
by awashko 3/27/2014 8:13:43 AM(UTC)
ice maker not getting water (Refrigerator & Freezer Repair)
by jmr82 2/4/2013 10:01:51 PM(UTC)
by markplee@comcast.net 4/23/2012 7:58:24 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
by redgtfour 2/19/2012 2:00:54 PM(UTC)
ge monogram - ice maker not getting water (Refrigerator & Freezer Repair)
by jmeurer 12/23/2011 8:41:41 PM(UTC)
Ice Maker not getting water (Refrigerator & Freezer Repair)
by garye 2/28/2010 4:02:28 AM(UTC)
Ice Maker Not getting water (Refrigerator & Freezer Repair)
by headtester 8/7/2009 8:27:51 AM(UTC)
Whirpool ice maker not getting water (Refrigerator & Freezer Repair)
by bjustice 5/6/2009 9:13:54 AM(UTC)
by bwseabee@yahoo.com 5/29/2008 3:21:32 AM(UTC)
Frigidaire Ice Maker not getting water & not working (Refrigerator & Freezer Repair)
by Salpal 9/26/2007 8:39:11 AM(UTC)
by DBBromberg1 9/12/2007 7:52:36 AM(UTC)
Ice maker not getting water. (Refrigerator & Freezer Repair)
by brandon58 7/30/2007 12:09:33 PM(UTC)
