twarshavsky
#1 Posted : Monday, October 4, 2010 7:48:14 AM(UTC)
twarshavsky
The right front burner would not always come on, when it did the flame was irregular and flames would come out of the air opening in the connecting tube. We replaced both the back and front burner, the back burner works fine, but the front burner still has the problem. What to do?
Joe / APP Team
#2 Posted : Monday, October 4, 2010 1:28:15 PM(UTC)
Joe / APP Team
You should check the oriface (brass fitting that the burner tube encloses)for clogs, dirt, grease etc.
If thats proper, you will need to replace the burner valve .
Part number: AP4284817
Good Luck,
twarshavsky
#3 Posted : Friday, October 8, 2010 7:01:07 AM(UTC)
twarshavsky
We did what you suggested and it worked. My husband still doesn't believe it was that simple. Thanks alot.:p
Joe / APP Team
#4 Posted : Friday, October 8, 2010 8:04:04 AM(UTC)
Joe / APP Team
We're glad it was that simple,
and happy that you're happy
You're welcome,
:D :D :D
Burner Problems for Kenmore 790.99123404 Range (Oven Repair (including Ranges and Cooktops))
by whitedavidp1 1/17/2020 12:51:57 PM(UTC)
Whirlpool stove burner problem (Oven Repair (including Ranges and Cooktops))
by Cardiaccat 2/24/2019 5:22:18 PM(UTC)
Viking Gas Range Burner Problem (Oven Repair (including Ranges and Cooktops))
by pd78 1/23/2019 4:12:13 AM(UTC)
Wolf SB486 Burner Problem/Adjustment (Oven Repair (including Ranges and Cooktops))
by HRMCHAN 9/6/2016 6:51:06 AM(UTC)
Burner problem (Oven Repair (including Ranges and Cooktops))
by donnahi5 9/27/2015 6:13:22 AM(UTC)
One burner problem: on-off-or full heat; nothing else (Oven Repair (including Ranges and Cooktops))
by efahrens 7/20/2015 7:29:12 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
GE Burner Problem (Oven Repair (including Ranges and Cooktops))
by HkyFrk 4/3/2012 6:56:33 AM(UTC)
Americana Burner Problem (Oven Repair (including Ranges and Cooktops))
by Ken King 2/9/2012 9:21:08 AM(UTC)
Off & on Burner Problem (Dryer Repair)
by Nancy McMullen 12/27/2011 9:03:37 PM(UTC)
by rnhamski 10/7/2011 5:01:44 AM(UTC)
oven burner problem (Oven Repair (including Ranges and Cooktops))
by richtfan 4/26/2011 2:00:03 PM(UTC)
kitchen aid cooktop dual burner problem (Oven Repair (including Ranges and Cooktops))
by danjoc 4/12/2010 5:53:13 PM(UTC)
by jstaples 3/20/2010 11:08:13 AM(UTC)
kitchenaid kgrt500bal2 front burner problem (Oven Repair (including Ranges and Cooktops))
by hgminnesota 10/2/2009 3:32:17 PM(UTC)
