jdiddle
#1 Posted : Friday, October 1, 2010 4:38:38 AM(UTC)
jdiddle
please help, i am at my witts end here and the wife is going crazy...My oven will no light. I have a Magic chef 6257xus with the glow element instead of the pilot light for lighting. when the oven stopped working i replaced the regulator and that didn't work then i replaced the oven valve and that doesn't work either. there really isn't much else i can find to do. I started thinking thermostat and i found the papers on this and checked the wire schematic and from what i can tell if the element lights up then all of the electrical parts should be working fine. do you think i may have recieced a bad valve? if i break the connection between the reg. and valve i have gas flow.:confused:
Joe / APP Team
#2 Posted : Friday, October 1, 2010 7:58:35 AM(UTC)
Joe / APP Team
J,
You most likely had, and still have a weak igniter.
Part number: AP4012072
If the igniter Does glow, that indicates the thermostat or control and wiring is OK, and working(99%).
However, when the igniter glows, it must produce a minimum of 3.2 amps and 3.2 volts to the gas valve, in order to open the internal switch and release the gas for ignition.
If you don't have a meter, if you observe the igniter, it should glow "white" hot in 20 to 30 seconds, (you can barely look at it)if you can look at it , if it's glowing red or orange in color , it's weak, and you need to replace it.
Good Luck,
jdiddle
#3 Posted : Friday, October 1, 2010 9:17:56 AM(UTC)
jdiddle
thank you very much, i just ordered one. mine glows orange like you was saying. thanks again. hopefully this will take care of it.
Joe / APP Team
#4 Posted : Friday, October 1, 2010 11:35:27 AM(UTC)
Joe / APP Team
J,
I'm pretty sure that's what you're going to find.
Good Luck,
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
by PatY 8/16/2010 6:34:08 PM(UTC)
