Replacement parts for WHIRLPOOL LE7680XSW1 | AppliancePartsPros.comUnfortunately I cannot find a wiring diagram for this unit so the following is just general info.
Did you actually measure any of the parts with a meter or were you just guessing?
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
[COLOR="Red"]Be careful 240 volts is lethal.[/COLOR]If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 to 12 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Not sure what thermal devices you replaced as the unit has two thermal fuses. Near the heater is a thermal fuse for it and a hi-limit thermostat.
The main cycling thermostat is on the blower.
There is always a possibility that you received a bad part.
