Ratty555
#1 Posted : Thursday, September 16, 2010 11:20:54 AM(UTC)
Ratty555
I have a dacor double oven. The upper door latch assembly went out. The dacor oven model is#PCS 2305 The part # of the latch assembly is#
ML001005 82834. I was sent a model # 86166, and told it is a factory replacement. It does not fit. Is there some work around to make it fit?
#2 Posted : Thursday, September 16, 2010 3:50:15 PM(UTC)
Dacor has redesigned this part and changed the part number. 86166 is the correct part number for this model number.
These instructions might help you to install it properly.
Ratty555
#3 Posted : Thursday, September 16, 2010 5:03:30 PM(UTC)
Ratty555
You didn't even look at what i asked about. Not the oven light! It is thelatch mechanism that is used to.. lock the oven when you use the self cleaning option. The new mechanism does not fit
#4 Posted : Monday, September 20, 2010 1:40:31 PM(UTC)
It was not me! You are the one who did not read the instructions carefully. There are THREE pages and you've read only the first page.
Ratty555
#5 Posted : Monday, September 20, 2010 2:52:14 PM(UTC)
Ratty555
Well reading the three pages still does not address the problem. These are 2 different mechanisms. They have a different movement. You have to look at the 2 side by side to see why this is not a good replacement. I am able to wire
the replacement unit in to make the oven work, but the door latch will not work on this oven.
#6 Posted : Monday, September 20, 2010 3:03:35 PM(UTC)
You can try to call Dacor tech support. Some time they can be very helpful.
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
replacing door latch assembly (Washer Repair)
by JimBradenton 3/23/2012 5:21:14 AM(UTC)
door latch assembly replaceing (Dishwasher Repair)
by johna0721 10/14/2009 10:16:19 AM(UTC)
Dishwasher door latch assembly (Dishwasher Repair)
by Jerry48 10/6/2009 12:50:14 PM(UTC)
door latch assembly fell out and I need help! (Dishwasher Repair)
by chellebyerly 5/7/2009 8:54:34 AM(UTC)
How to replace door latch assembly on Maytag front loading machine (Washer Repair)
by Jake Magish 12/29/2008 2:58:16 PM(UTC)
Door Latch Assembly Broken (Washer Repair)
by steffd 6/21/2008 10:33:47 AM(UTC)
Broken door latch assembly (Microwave Repair)
by jf1942 3/12/2008 8:14:52 PM(UTC)
Door latch assembly or user interface? (Washer Repair)
by CMC1 8/7/2007 3:54:09 PM(UTC)
Maytag Front loader door latch assembly (Washer Repair)
by bpcolll 8/3/2007 10:40:07 AM(UTC)
