CMC1
#1 Posted : Tuesday, August 7, 2007 3:54:09 PM(UTC)
CMC1
The waher seems fine when selecting a cycle. All appropiate LEDs light up but the machine will not start(the door does not latch electronically. I tried to reboot it by following the reboot protocols. however the Led will only go down to 2 minutes it will not clear. I tried to leave the machine unplugged for hours not minutes.
#2 Posted : Friday, August 10, 2007 9:15:30 PM(UTC)
CMC1
Run the diagnostic test described in the technical data for your washer. It should be supplied with your washer but if do not have one you can find it here: Service Matters - Tech Sheets / Wiring Diagrams
