AtollMan
#1 Posted : Sunday, September 12, 2010 8:31:11 AM(UTC)
AtollMan
Top Loading
Tub fills right to the top,
and at beginning of the spin, as it starts to spin the water sloshes out.
Drain hoses and drain ok
Have checked the solenoid ok
Have replaced the level switch with new one
the air hose to the level switch is in good condition
the pumps seems to work fine
it seems the level is too high at the beginning of spin,
or the timing is off, the water level has not gone enough or fast enough
any idea's
Chuck
AtollMan
#2 Posted : Sunday, September 12, 2010 9:14:14 AM(UTC)
AtollMan
The water level switch works ok,
the air hose does not leak air,
Normally
after the agitate wash cycle the motor stops and reverses direction
with the reversing of direction to spin the pump starts.
The problem is before this 3/4 of the way though the wash agitate cycle (before reversing direction to spin) the drum slowly starts to spin faster and faster till the water starts to slosh out, just before the reversing of direction to spin and pumping out of water
thanks for any ideas
Chuck
AtollMan
#3 Posted : Sunday, September 12, 2010 12:21:55 PM(UTC)
AtollMan
Better description,
I've watched this many times,
Maytag top load washing machine LAT9606AAE will go into a slow rotation while agitating. This causes water to slosh over the top of the tub.
Is there a brake unit need to be replaced?
Thank you
AtollMan
#4 Posted : Sunday, September 12, 2010 5:42:58 PM(UTC)
AtollMan
tube slowly starts spinning in agitate cycle?
throws off water?
its toast.
it's in the the ....
Transmission
Home Owner (Refrigerator & Freezer Repair)
by Dennis Steen 6/4/2015 8:29:00 AM(UTC)
home owner (Refrigerator & Freezer Repair)
by wayfran67@q.com 1/8/2013 7:36:37 AM(UTC)
home owner (Dishwasher Repair)
by dalmil 9/23/2011 6:21:22 AM(UTC)
Home Owner (Washer Repair)
by kdchase 3/28/2011 3:43:45 PM(UTC)
by kdchase 3/27/2011 4:47:16 PM(UTC)
home owner (Oven Repair (including Ranges and Cooktops))
by louismok 8/9/2010 1:43:29 PM(UTC)
Storm. home owner (Oven Repair (including Ranges and Cooktops))
by Storm Totten 7/27/2010 3:06:12 PM(UTC)
getting GE to send part to home owner (Refrigerator & Freezer Repair)
by lmm 1/4/2010 2:36:35 PM(UTC)
by KLOPS 8/3/2009 12:15:51 PM(UTC)
by tom ponsford 3/11/2009 8:17:13 AM(UTC)
home owner (Dryer Repair)
by portincaso 5/24/2008 2:26:38 PM(UTC)
