vrapp
#1 Posted : Thursday, July 10, 2008 3:04:44 PM(UTC)
vrapp
Hello,
the water level switch recently stopped working. Regardless of the position of the slide control, the tank gets filled with water until it's full. Then it stops filling, and the washer begins agitating as usual. But there's no way to fill the tank half-full, for instance.
I replaced water level switch for a new one, purchased from this site, but it did not help.
I measured electric resistance between terminals of the switch with empty and with full tank, and they are as should be - closed circuit between one pair with empty, closed between another will full. But position of the slide control does not have any effect.
The rubber air pressure hose appears intact.
What else to look at?
vrapp
#2 Posted : Friday, July 11, 2008 3:44:50 AM(UTC)
vrapp
further development... after several attempts to try this and that, changing new water level switch to new and back, now the water doesn't stop even when the tank is full. I still can stop it manually by the round knob.
I confirmed that there's no leak in the air hose by trying to blow into it with the water in the tank.
#3 Posted : Friday, July 11, 2008 5:37:27 PM(UTC)
Check for 120VAC to the water inlet valve coils. Check if removing the wires will stop filling.
vrapp
#4 Posted : Friday, July 11, 2008 6:20:14 PM(UTC)
vrapp
yes, when the water is pouring in, there is 120VAC on them. If cold water, on one coil, if hot, on another.
yes, removing the wires does stop filling.
#5 Posted : Friday, July 11, 2008 6:33:46 PM(UTC)
Check the "check" switch. If it's shorted, according to the wiring diagram, it can cause such problem.
Here are the break down diagrams for the Maytag washer Model LAT5916AAE
vrapp
#6 Posted : Friday, July 11, 2008 8:17:29 PM(UTC)
vrapp
"check" switch, as I understand, is part of the lid switch assembly, right? I couldn't get it apart, but I measured the resistance between the terminals. "Line" and "Machine" were always shorted; "motor" and "machine" were shorted with closed lid, open with open lid. The water pours into the tank regardless of the lid; opening the lid stops the motor when it's working.
#7 Posted : Monday, July 14, 2008 5:21:16 PM(UTC)
Check switch is a part of the lid switch assembly. Refer to the break down diagrams.
vrapp
#8 Posted : Thursday, July 17, 2008 1:22:26 PM(UTC)
vrapp
Finally, figured out where the problem was - in the air hose. The hose was intact, no holes etc., but some debris clogged it a little in the wide part where it attaches to the tank. The air was still moving in the hose, but obviously the debris affected the pressure transmitted to the switch. I detached the hose from the tank, cleaned it, and that fixed the problem.
#9 Posted : Thursday, July 17, 2008 3:54:19 PM(UTC)
I'm glad you were able to find the problem and fix it.
LG top loading water level not correct (Washer Repair)
by Guest 12/7/2023 6:44:59 AM(UTC)
GE Washing machine water level problem (Washer Repair)
by Guest 12/3/2022 12:53:02 AM(UTC)
LG WATER LEVEL SENSOR (Washer Repair)
by NicholaF 9/20/2022 9:59:26 AM(UTC)
Auto Sensing Water Level (Washer Repair)
Belarus nwr251 7/21/2022 4:23:08 PM(UTC)
Low water level in GE PDW8280 (Dishwasher Repair)
by b707guy 8/1/2021 1:49:44 PM(UTC)
New Maytag Washer Water Level (Washer Repair)
by RCRICK 1/8/2021 8:36:02 AM(UTC)
Need To Increase the Water Level (Washer Repair)
by retab12332 12/2/2020 1:54:37 PM(UTC)
Setting water level on old(er) Whirlpool top load (Washer Repair)
by M Yaworski 4/12/2020 11:54:35 AM(UTC)
GE Dishwasher water level about 1/4" too high (Dishwasher Repair)
by sup 1/4/2018 5:49:22 PM(UTC)
water level control (Dishwasher Repair)
by pfoxharp 12/29/2017 7:15:54 AM(UTC)
Whirlpool rinse water level low (Washer Repair)
by g20zoom 8/19/2016 6:49:58 PM(UTC)
water level pressure switch (Washer Repair)
by onesunshine 11/29/2015 5:23:33 PM(UTC)
Water level too low (Washer Repair)
by asagy 10/22/2015 5:16:26 AM(UTC)
How replace water level knob on Kenmore (Washer Repair)
by John7778 8/20/2015 9:53:43 AM(UTC)
Roper Whirlpool Washer - Water Level Knob Won't Turn (Washer Repair)
by jonnyv88 8/12/2015 5:54:48 PM(UTC)
