This is a heavy duty top load washer. My tenant keeps nagging me and swears that the rinse cycle used to fill up all the way. They have used this machine 5 years. I've been reading and filling up a partial tub is "normal" to conserve water on the rinse cycle. The machine fills about 1/2 way. Does that seem right? It was bought new around Oct 2011. To be safe, I did blow in the clear tube for the pressure switch, and that was clear. I found this video.... https://youtu.be/Sgiu2yYPUyQand seems to describe the enough, but i'm not sure how to convince this person. Maybe their memory aging...sure sounds like it. Thanks!
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
I believe your machine has two pressure switches check both lines for obstruction.
Correct. Both switches Tee together. I disconnected the single line going to the tub and that blew clear. The other lines were visible connecting to each press switch. I still get 1/2 tub fill. But the bypass does work to fill tub all the way. I think the tenant is mistaken since she thinks it's not Washing as well ...
