g20zoom
#1 Posted : Friday, August 19, 2016 6:49:58 PM(UTC)
g20zoom
This is a heavy duty top load washer.
My tenant keeps nagging me and swears that the rinse cycle used to fill up all the way. They have used this machine 5 years. I've been reading and filling up a partial tub is "normal" to conserve water on the rinse cycle. The machine fills about 1/2 way. Does that seem right? It was bought new around Oct 2011.
To be safe, I did blow in the clear tube for the pressure switch, and that was clear.
I found this video....
https://youtu.be/Sgiu2yYPUyQ
and seems to describe the enough, but i'm not sure how to convince this person. Maybe their memory aging...sure sounds like it.
Thanks!
brobriffin
#2 Posted : Monday, August 22, 2016 2:44:45 PM(UTC)
brobriffin
Rank:: Member
Groups ready for retrieval: Registered
Man
United States
I believe your machine has two pressure switches check both lines for obstruction.
g20zoom
#3 Posted : Monday, August 22, 2016 3:01:27 PM(UTC)
g20zoom
Correct. Both switches Tee together. I disconnected the single line going to the tub and that blew clear. The other lines were visible connecting to each press switch. I still get 1/2 tub fill. But the bypass does work to fill tub all the way.
I think the tenant is mistaken since she thinks it's not Washing as well ...
