slee0064@aol.com
#1 Posted : Tuesday, September 7, 2010 10:12:28 AM(UTC)
slee0064@aol.com
roper direct drive wont spin,lid switch ok and trans to motor ok.motor comes on and spins but trans shaft not turning.disassembled trans found one of the plastic arms on the neutral drain assy worn and looked broke on the end,could this be my problem.
Joe / APP Team
#2 Posted : Tuesday, September 7, 2010 1:51:42 PM(UTC)
Joe / APP Team
Slee,
Yes, and it most likely is.
That end, you say appears broken, actuates the clutch pads and expands the clutch pads, so they lock to the spin tube and spins the tub.
I doubt if you need any of the spin tube parts but you are going to need the Brake / clutch kit.
Part number: AP3094537
#3 Posted : Wednesday, September 8, 2010 1:16:07 AM(UTC)
RE-assemble the tranny and turn the coupler clockwise. If the tranny fails to turn the clutch plate, you need a new tranny. They do sell a neutral assembly, part # 388253, or a spin gear set 285362
I would not recommend fixing the tranny as you just might have bad bushings in it.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
Whirlpool LTE6234DQ2 Wont Spin (Washer Repair)
by kelgun 12/7/2023 2:53:34 PM(UTC)
my fully automatic washer,(top loader) WONT SPIN (Washer Repair)
by johnsail2000 4/14/2023 8:51:18 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
GE top load wont spin (Washer Repair)
by NOELLE.EUAN 10/15/2017 5:03:37 PM(UTC)
Hotpoint wont spin or drain (Washer Repair)
by Snowostrich 7/1/2017 2:53:32 PM(UTC)
by malakye 3/5/2017 1:18:25 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
Kenmore wont spin or drain. no noise. Lid switch does click. (Washer Repair)
by DCAJR1 8/17/2016 12:09:50 PM(UTC)
Wont spin on *some* settings (Washer Repair)
by merkman 7/18/2016 7:15:38 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytage wont spin (Washer Repair)
by Mike055 12/10/2015 11:15:41 AM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
