My washer will fill and drain but will not spin when it gets to that cycle. I have troubleshot a few things: 1. I removed the front to access the hose on the left that is connected to the load size dial. It was not clogged and I sucked and blew into the hose several times and heard clicking. I replaced the hose and it still didn't spin. 2. I unplugged the washer and waiting about 5 minutes before plugging it back in. After plugging it in, I immediately opened and closed the lid six times within a few seconds. 3. I checked the belt and it appears to be in good condition and in place. 4. I manually spun it myself to make sure there was nothing blocking it.
Any other ideas?
Rank:: Member
GE Washer Model WJRE5550K2WW will not spin. Pump works and drains just fine. Lid switch works, the water level switch checks out, there are no codes coming up on the motor LED, belt is in good shape, inner tub can be easily turned by hand in either direction. I tried a reset and it made no difference. The timer is a computerized model and I do not know how to check it but I have done everything else that I can think of to find the problem. Any ideas? Washer is 7 years old
