moportom
#1 Posted : Sunday, June 29, 2008 3:46:44 PM(UTC)
moportom
washer does nothing does not fill with water or start
#2 Posted : Monday, June 30, 2008 12:30:26 PM(UTC)
Check if there is 120VAC at the power outlet. Check the power cord.
If there is nothing wrong then check for 120VAC between the "V" wire at the water level switch and neutral (remove the "V" wire from the terminal prior to test) while the timer is in "on" position.
If there is 120VAC then the water level switch is bad and has to be replaced.
If there is no 120VAC then the timer is bad and has to be replaced.
- The part number for the timer is AP2911959
- The part number for the water level switch is AP2905822
Here are the break down diagrams for the Whirlpool washer Model LA7000XTW1
moportom
#3 Posted : Friday, July 4, 2008 2:16:56 PM(UTC)
moportom
now fills with water now but does not wash or spin
#4 Posted : Saturday, July 5, 2008 4:14:09 PM(UTC)
Did you run any tests from the previous reply?
moportom
#5 Posted : Saturday, July 5, 2008 4:55:38 PM(UTC)
moportom
yes now it fills with water when itgoes to next cycle it just buzzs
i can move agitator by hand but drum will not move.
#6 Posted : Saturday, July 5, 2008 5:09:47 PM(UTC)
Remove the cabinet and check the motor plug and all wires to the motor.
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
Ge Profile. Oven bake works. But convention does not work. Fan runs. (Oven Repair (including Ranges and Cooktops))
by Guest 2/23/2022 10:46:18 AM(UTC)
Samsung FL Washer Replacement rear half tub does not work with existing drain pump location (Washer Repair)
by motoman3 1/14/2020 8:12:15 PM(UTC)
GE spin cycle does not work (Washer Repair)
by jalyons 1/23/2019 12:36:19 PM(UTC)
Maytag Neptune Model MDE5500AYW-Timed dry feature does not work (Dryer Repair)
by Bodangles 1/20/2019 11:47:14 AM(UTC)
Maytag MD-1 Gas Dryer Auto Dry Does Not Work (Dryer Repair)
by FGA1939 12/17/2017 7:47:38 AM(UTC)
Oven and Broiler does not work (Oven Repair (including Ranges and Cooktops))
by Travisceo 8/15/2017 11:43:20 AM(UTC)
Washer does not work (Dishwasher Repair)
by edmiller 12/19/2016 6:57:17 AM(UTC)
self cleaning option does not work (Oven Repair (including Ranges and Cooktops))
by jackbuettner@msn.com 10/6/2016 1:03:43 PM(UTC)
Kenmore Elite refrigerator water dispenser does not work (Refrigerator & Freezer Repair)
by pickmari 9/15/2016 5:00:32 PM(UTC)
by MikesrAPP 9/13/2016 7:14:53 AM(UTC)
My dryer all of a sudden does not work at all (Dryer Repair)
by mpgarcia6969@gmail.com 8/28/2016 9:12:33 PM(UTC)
Evaporator Fan Does Not Work When Freezer Sensor is Plugged In (Refrigerator & Freezer Repair)
by bogey24 12/22/2015 3:02:41 PM(UTC)
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 6/5/2015 10:52:55 AM(UTC)
