AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Neptune Model MDE5500AYW-Timed dry feature does not work
Joined: 1/20/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: florida
Everything on the dryer works fine and drys fine. There is a dying feature where you set the drying by time but it doesn't work.
I am mechanically inclined and so would like to repair this myself...so far I have assumed it may be the control board ..(hoping not).
Any thoughts that could help?
Derrick
Joined: 2/7/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Washington
I had a similar problem. The dryer timer would not turn off at the end of any cycle except for the fluff air cycle. After replacing the timer twice, the real problem turned out to be the start switch. A little amplifying information: Each timer replacement would work properly for about a week. Then it would keep the dryer on through all the cycles until it went through the fluff air cycle. Whirlpool Dryer Model LGR6634BQ2 Edited by user Thursday, February 7, 2019 8:30:04 AM(UTC)
| Reason: Not specified
Dryer Repair
