The auto dry function of this 2006 dryer does not work. However the time drying does do well. I have seen other posts regarding this same issue with other models, with positive results by replacing a thermal switch. Does this apply to the MD-1? And where might there be found a video on replacement of any part concerning this issue? Thanks, fga1939
I am not certain about this model but my guess is that the timer is at fault. The contacts in the timer are not making connection for the function involved. Unless you want to spend a lot of $ for a new timer I suggest you live with it. Timers can get to be fairly expensive.
