debbiea3624
#1 Posted : Thursday, August 5, 2010 5:26:33 AM(UTC)
debbiea3624
My refrigerator is warm the freezer is cold. Can anyone tell me what is wrong or what I can check. Do you think I need a new one or can I repair what I have for under 300.00. Really need help ASAP
Debbie
Joe / APP Team
#2 Posted : Thursday, August 5, 2010 7:05:31 AM(UTC)
Joe / APP Team
Debbie
Debbie,
You need to do 3 quick checks :
1) Can you hear a fan running,when you open the freezer door ?
2) Look on the back wall of the freezer compartment, do you see a heavy build up of snow, frost or ice ?
3) Check your controls, did they get reset / moved by accident or mistake ?
I think you may have a defrost problem or inoperable evaporator fan.
I'm not aware of current labor or parts charges, but I would think the cost would be in your budget range.
:cool:
debbiea3624
#3 Posted : Thursday, August 5, 2010 7:12:29 AM(UTC)
debbiea3624
I do hear the fan and I do not see any frost or snow. I did take the back bottom out and there was alot of dust that I cleaned out the fan was blowing. Sorry I am not very good at this but would like to try to fix it myself so any help you can give me would be great!!!
Joe / APP Team
#4 Posted : Thursday, August 5, 2010 11:17:29 AM(UTC)
Joe / APP Team
You may have solved your problem, when you cleaned all the dust and debris from the condenser coil and compressor compartment.:confused:
Are you sure there is nothing blocking the air tunnels (1 is up near the ceiling and 1 is down near the crisper drawers,and both are on the left wall of the fresh food compartment. If those are blocked by an article, the air flow is restricted and the fresh food compartment gets warm.
And you're sure when you opened the freezer door you could hear and, maybe even feel the evaporator fan running ?
And your control knobs are at the right setting(s) ?
Let it run 24 hours, and contact us if the problem is not resolved.:)
debbiea3624
#5 Posted : Thursday, August 5, 2010 11:25:03 AM(UTC)
debbiea3624
I will double check everything when I get home...I will update you tomorow...thanks so much for your help
Debbie
Joe / APP Team
#6 Posted : Friday, August 6, 2010 6:22:43 AM(UTC)
Joe / APP Team
Debbie
OK,
We look forward to hearing from you. :)
debbiea3624
#7 Posted : Friday, August 6, 2010 6:25:07 AM(UTC)
debbiea3624
I rechecked when I got home I do have some frost (snow) on the back of the freezer. I can still hear the fan
Joe / APP Team
#8 Posted : Friday, August 6, 2010 11:20:59 AM(UTC)
Joe / APP Team
The frost(snow) on the wall, indicates a failed defrost cycle component.
Any 1 of 3 components could have failed:
Defrost timer or control
Defrost heater
Defrost thermostat
Turn your fridge off for a few hours(8 to 10), or when you go to bed.
and turn it back on after that, it should work satisfactory for a few days(3 to 5) before you start having a problem with the cooling.
I don't know what you have in mind, as far as repairing your fridge, test and replace the needed part(s) just replace the part(s), or etc.
Either way, I think you'll still be within your budget.
debbiea3624
#9 Posted : Friday, August 6, 2010 2:49:30 PM(UTC)
debbiea3624
OMg...thank you so much...You are right on the mark...I had a repair man come over and thanks to you I did not sound like an idiot. He fixed the fridge by replacing as you said the Defrost Thermostate and the Defrost Timer..total cost was $168.00 with labor. I know I could have saved some money doing it myself but I was unsure. Either way not a bad price. You are awesome....Thanks again
Debbie
Joe / APP Team
#10 Posted : Monday, August 9, 2010 6:24:54 AM(UTC)
Joe / APP Team
Debbie
Thank you for the response.
I'm glad everything went well, and turned out great for you.
We're more than happy to help.
Hopefully we will be able to help in the future.
Freezer working, refrigerator warm (Refrigerator & Freezer Repair)
by Hero 12/31/2021 6:48:52 AM(UTC)
Refrigerator warm 45 degrees , freezer gets very cold then warms up (Refrigerator & Freezer Repair)
by sgordonson 9/25/2020 7:31:42 AM(UTC)
Refrigerator warm, freezer cold, frost buildup on back of freezer (Refrigerator & Freezer Repair)
by Geoff Hess 8/15/2017 8:31:32 AM(UTC)
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9/7/2016 6:50:59 PM(UTC)
Electrolux - refrigerator warm - freezer good - cooling drawer good (Refrigerator & Freezer Repair)
by smnorrick 2/5/2016 11:22:03 AM(UTC)
Refrigerator warm and cold (Refrigerator & Freezer Repair)
by David T 7/16/2015 10:29:23 AM(UTC)
Freezer defrosts and refrigerator warms (Refrigerator & Freezer Repair)
by problems 11/10/2014 4:40:42 PM(UTC)
Freezer Cold Refrigerator Warm - Evap Fan Runs Intermittently (Refrigerator & Freezer Repair)
by Mkorns 5/27/2014 10:52:33 AM(UTC)
Refrigerator Warm / Freezer Cold (Refrigerator & Freezer Repair)
by lukewarm 11/1/2013 9:21:13 AM(UTC)
GE Freezer and refrigerator warm, frost on coils-what should an amateur change first? (Refrigerator & Freezer Repair)
by dfavelo 10/2/2013 6:55:19 PM(UTC)
Freezer seems fine, refrigerator warm, found frost on return vent at top (Refrigerator & Freezer Repair)
by Cczkcb 10/1/2013 2:42:34 AM(UTC)
Refrigerator warm Freezer ok (Refrigerator & Freezer Repair)
by larbear 8/24/2013 7:24:21 PM(UTC)
Refrigerator Warm Light not working (Refrigerator & Freezer Repair)
by blueeyes243 4/15/2013 7:07:22 AM(UTC)
Refrigerator warm, coils frozen solid (Refrigerator & Freezer Repair)
by tom1799 9/12/2012 8:13:10 AM(UTC)
Refrigerator warm, freezer fine. (Refrigerator & Freezer Repair)
by gandswalton 9/2/2012 1:34:35 PM(UTC)
