andolescia
#1 Posted : Sunday, July 11, 2010 8:24:24 AM(UTC)
andolescia
My washer will not agitate during the wash and rinse cycle but it will during the draining of the water....please help?
sidfink43
#2 Posted : Monday, July 12, 2010 11:37:35 AM(UTC)
sidfink43
Unfortunately GE does not release technical data on your machine, so we can only take an educated guess.
In your case, if the machine is agitating while it is draining the transmission is the likely problem. Before doing anything though I would check all of the wiring coming into and going out of the timer.
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
GE washer won't agitate (Washer Repair)
by jgkjak 7/26/2013 1:27:18 PM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
GE washer Won't agitate does everything else (Washer Repair)
by jbryant1105 4/11/2013 7:04:08 AM(UTC)
Ge washer won't agitate or spin (Washer Repair)
by Mit0410 3/22/2012 1:40:13 PM(UTC)
by kw2107 9/9/2011 11:19:11 AM(UTC)
GE washer won't agitate or spin (Washer Repair)
by rockfixer 5/23/2011 12:40:19 PM(UTC)
Ge washer won't agitate spin or drain (Washer Repair)
by Kevin2685 4/18/2011 7:42:21 PM(UTC)
GE Washer won't agitate (Washer Repair)
by Winfield 4/16/2010 6:51:56 PM(UTC)
by MICHELLE1996 4/4/2010 4:55:25 PM(UTC)
GE Washer won't agitate properly and can't figure out which part to get. (Washer Repair)
by phin66 1/24/2010 6:56:10 AM(UTC)
ge washer won't agitate or spin (Washer Repair)
by dgdc 2/23/2009 4:27:02 PM(UTC)
Ge Washer Won't Agitate/Spin (Washer Repair)
by cus70 2/17/2009 7:21:04 AM(UTC)
Ge Washer Won't Agitate/Spin (Dishwasher Repair)
by cus70 2/17/2009 7:15:57 AM(UTC)
