Mit0410
#1 Posted : Thursday, March 22, 2012 1:40:13 PM(UTC)
Mit0410
My ge washer will not agitate or spin. Any ideas????? I have tested the lid switch and it works correctly.
Gary/APP Team
#2 Posted : Friday, March 23, 2012 6:02:14 AM(UTC)
mattt
Groups:
Hello. There is a small green led light on top of the motor that displays a failure code ,in a series of blinks, this will determine whether it is the motor,
the mode shifter or the inline fuse link , I have sent you 2 files that explain.
Part number: AP4390012
sidfink43
#3 Posted : Friday, March 23, 2012 5:34:50 PM(UTC)
sidfink43
If you take off the front panel you should see a flashing green light on the motor. That is generating error codes. Use this link to interpret them.
Start by trying to reset things. Some times that is all it takes.
HydroWave GE Washer Repair Guide
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
GE washer won't agitate or spin (Washer Repair)
by rockfixer 5/23/2011 12:40:19 PM(UTC)
ge washer won't agitate or spin (Washer Repair)
by dgdc 2/23/2009 4:27:02 PM(UTC)
