2 Pages12>
JOES
#1 Posted : Thursday, April 10, 2008 7:24:12 AM(UTC)
JOES
The "extra Low" Right Front Burner On The Cooktop Just Stopped Working. The Igniters Will Spark But I Get No Gas Flow From The Burner. Could It Be The Solenoid For That Burner? How Do I Get To It? Do You Have To Remove The Cooktop From The Counter?
gearhead1218
#2 Posted : Friday, April 11, 2008 5:20:56 PM(UTC)
gearhead1218
Those potentiometers just love to go bad on the Thermadors. I just got bit on that recently and learned a few things on them. The replacements are better amd come as a kit that includes a new simmer controller.
The selonoids while not trouble free are pretty reliable from what I hear.
sreng
#3 Posted : Friday, June 6, 2008 10:32:13 AM(UTC)
sreng
UserPostedImage Thermador Cook Top SGCS365RW
JOES, I have the same problem as you, though a different model#.
Did the kit solve your problem?
gearhead1218, do you recommend the same for me?
Thanks.
gearhead1218
#4 Posted : Friday, June 6, 2008 4:32:48 PM(UTC)
gearhead1218
The potentiometers that are being sent out with this kit are a little different than the old ones. The MFG. won't admit it, but the old ones are crap.
sreng
#5 Posted : Saturday, June 7, 2008 4:03:07 AM(UTC)
sreng
gearhead1218, thanks for your response.
Is that kit part # AP3572616 ?
It seems as if that kit is recommended for several different Thermador cooktops. Is it a "one size fits all" situtation?
sreng
#6 Posted : Tuesday, June 10, 2008 12:22:14 PM(UTC)
sreng
Thermador cooktop SGCS365RW, Serial # 98090557M
Front xlo burner not lighting.
I ordered AP's AP3872616 (Bosch part No, 497235) potentiometer kit yestereday, received it today.
I installed the new simmer controller and the new potentiometers. The only thing that happened when I tried it was that gas came out of the back right burner, but there was no ignition at any burner.
I replaced the original parts, reversing the two original potentiometers. Then four of the five burners worked again, but not the rear center (xlo). Now the front xlo lites fine.
I called Thermador customer service. Only an authorized repair person can get information from their technicians.
Does the new kit require something other than a simple swap?
Could the simmer controller be defective?
sreng
#7 Posted : Thursday, June 12, 2008 6:20:20 AM(UTC)
sreng
Did a reinstall of the new parts today and all burners are working properly. It is a simple swap.
redwood42
#8 Posted : Tuesday, September 16, 2008 7:12:46 AM(UTC)
redwood42
DOes anyone know if this replacement kit will work on the Thermador SGSCV36G? I have the same problem with my left front extra low burner and every site says no part available.
#9 Posted : Tuesday, September 16, 2008 3:31:42 PM(UTC)
redwood42,
I would recommend to call the customer service (877-477-7278) and ask for Adam. He'll help you.
sreng
#10 Posted : Tuesday, October 27, 2009 8:11:31 AM(UTC)
sreng
That was in June of 08.
Oct 28, 2009 - Used the front extralow burner once this morning- all ok. Tried to use it a few moments later and heard a pop sound. Now both extralow burners are inopperative. Any suggestions?
Guest (10)
Old Thermador cook top mystery (Oven Repair (including Ranges and Cooktops))
by dee6634 6/21/2012 1:57:16 PM(UTC)
Thermador Cook Top (Oven Repair (including Ranges and Cooktops))
by gary@custominteriors 2/28/2011 11:14:03 AM(UTC)
Thermador cook top pop (Oven Repair (including Ranges and Cooktops))
by flip 5/13/2008 10:20:32 AM(UTC)
ignitor problem on Thermador cook top (Oven Repair (including Ranges and Cooktops))
by daneh 3/22/2008 9:04:33 AM(UTC)
2 Pages12>
