my icemaker seems to be making ice slower after all the ice was emptied out of the storage container. how long does it take to refill again?do ineed to change my freezer temperature settings or what?:confused:
smily The ice maker will produce seven cubes per cycle—approximately 100–130 cubes in a 24-hour period, depending on freezer compartment temperature, room temperature, number of door openings and other use conditions. Gene.
Not sure who is going to reply. Having difficulity understanding how to post a question!!! Anyway, I have a Kenmore Model 25376822400 in which the arm of the icemaker dispenser will not go back to the "on" position. This is very strange as prior to my Mother's memorial, (May 24th), the icemaker worked perfectly. Actually overloaded w/ice! If I'm home I can manually push the arm down and after a short time ice will eject but the arm remains in the up position. What do I do? Aside from my Mother's passing I'm soon preparing for divorce so I'm on my on! This refrigerator is a little over 2 years and I had to battle Sears for over 9 months just to get a refrigerator w/a icemaker that actually worked!:confused:
If the ice bin is not full of the ice cubes and the arm does not go down then, most likely, you have to replace the ice maker. - The part number for the ice maker is AP3966072 Gene.
