jlbonds
#1 Posted : Friday, June 25, 2010 7:54:39 AM(UTC)
jlbonds
Refrigerator temp is too cold on lowest setting. Ice in beverages. Freezer is ok. Is this a bad thermostat?
#2 Posted : Friday, June 25, 2010 12:41:56 PM(UTC)
How exactly did you set both controls (numbers)?
jlbonds
#3 Posted : Friday, June 25, 2010 1:29:10 PM(UTC)
jlbonds
I'm not looking at the controls at this time however I know that the setting for the refrigerator is on 1 and it's stii too cold. The freezer seems to be fine. Thanks for your help
#4 Posted : Friday, June 25, 2010 3:23:50 PM(UTC)
It is important how did you set the freezer control too.
jlbonds
#5 Posted : Friday, June 25, 2010 3:30:39 PM(UTC)
jlbonds
Gene,
I checked the freezer control setting and it was on 7 which is the highest setting. I have moved it back to 6 to see if that won't keep everything cold enough. Any advice? Thanks.
#6 Posted : Friday, June 25, 2010 4:11:29 PM(UTC)
Set the freezer control on 3 and wait about 24 hours. Put a thermometers in both compartments.
jlbonds
#7 Posted : Friday, June 25, 2010 4:25:36 PM(UTC)
jlbonds
Gene,
I will follow your instructions. Since we are going into weekend and I'm sure we won't be able to correspond, please advise what temps I should expect or hope to see in each compartment and what should my next move be. Thanks again for all your help.
Jeff
#8 Posted : Friday, June 25, 2010 4:33:58 PM(UTC)
Jeff,
Normally it suppose to be about 0°F in the freezer and between 35°F to 39°F in the fresh food.
Guest (5)
Top freezer refrigerator too cold. (Refrigerator & Freezer Repair)
by yaworski 2/15/2021 10:38:29 AM(UTC)
Samsung Refrigerator too cold (Refrigerator & Freezer Repair)
by jim.grove1 1/30/2020 10:26:16 AM(UTC)
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 10/26/2016 5:27:11 PM(UTC)
Frigidaire S x S refrigerator too cold (Refrigerator & Freezer Repair)
by APPLIANCEDUDE1972 12/11/2014 6:27:01 PM(UTC)
GE refrigerator too cold, unstable temp cycle (Refrigerator & Freezer Repair)
by James2000 5/23/2014 8:15:56 AM(UTC)
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11/16/2013 5:36:27 AM(UTC)
Refrigerator too cold, Freezer melting and refreezing (Refrigerator & Freezer Repair)
by ejnelson24 2/20/2013 3:48:45 PM(UTC)
KitchenAid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by famcar 12/21/2012 5:41:32 PM(UTC)
Refrigerator too cold and uncontrolable (Refrigerator & Freezer Repair)
by nailerdog 3/25/2012 7:57:15 AM(UTC)
by Old Wino 1/19/2012 7:52:56 AM(UTC)
Refrigerator Too Cold Vegetables Freezing (Refrigerator & Freezer Repair)
by olgapico 11/15/2011 7:43:20 AM(UTC)
by lgray215 10/12/2011 4:08:57 PM(UTC)
by jimmybass 9/16/2011 12:41:24 PM(UTC)
by TaniaH 4/1/2011 7:52:26 AM(UTC)
by Paul Sobus 3/9/2011 6:22:01 AM(UTC)
