pinzou
#1 Posted : Thursday, May 29, 2008 6:08:39 AM(UTC)
pinzou
I have an Americana stove made by GE. One of my burner stop working, I noticed the element is brioken so I changed the element and plug but it's not working but the light on the dash stay red. There is no power from the plug, could it be the control switch? Please reply.
Pinzou
pinzou
#2 Posted : Thursday, May 29, 2008 6:16:22 AM(UTC)
pinzou
I need help!
#3 Posted : Thursday, May 29, 2008 8:54:18 PM(UTC)
Remove the heating element and check for 240VAC at the receptacle block terminals while the switch is in "Hi" position.
If there is no 240VAC then check for burned wires at the receptacle block and receptacle block itself.
If there is nothing wrong then replace the switch.
- The part number for the large burner switch is AP2024074
- The part number for the small burner switch is AP2024071
- The part number for the receptacle block is AP3203326
Burner Problems for Kenmore 790.99123404 Range (Oven Repair (including Ranges and Cooktops))
by whitedavidp1 1/17/2020 12:51:57 PM(UTC)
Whirlpool stove burner problem (Oven Repair (including Ranges and Cooktops))
by Cardiaccat 2/24/2019 5:22:18 PM(UTC)
Viking Gas Range Burner Problem (Oven Repair (including Ranges and Cooktops))
by pd78 1/23/2019 4:12:13 AM(UTC)
Wolf SB486 Burner Problem/Adjustment (Oven Repair (including Ranges and Cooktops))
by HRMCHAN 9/6/2016 6:51:06 AM(UTC)
Burner problem (Oven Repair (including Ranges and Cooktops))
by donnahi5 9/27/2015 6:13:22 AM(UTC)
One burner problem: on-off-or full heat; nothing else (Oven Repair (including Ranges and Cooktops))
by efahrens 7/20/2015 7:29:12 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
GE Burner Problem (Oven Repair (including Ranges and Cooktops))
by HkyFrk 4/3/2012 6:56:33 AM(UTC)
Americana Burner Problem (Oven Repair (including Ranges and Cooktops))
by Ken King 2/9/2012 9:21:08 AM(UTC)
Off & on Burner Problem (Dryer Repair)
by Nancy McMullen 12/27/2011 9:03:37 PM(UTC)
by rnhamski 10/7/2011 5:01:44 AM(UTC)
oven burner problem (Oven Repair (including Ranges and Cooktops))
by richtfan 4/26/2011 2:00:03 PM(UTC)
by twarshavsky 10/4/2010 7:48:14 AM(UTC)
kitchen aid cooktop dual burner problem (Oven Repair (including Ranges and Cooktops))
by danjoc 4/12/2010 5:53:13 PM(UTC)
by jstaples 3/20/2010 11:08:13 AM(UTC)
