jstayoung1
#1 Posted : Thursday, June 10, 2010 12:37:53 AM(UTC)
jstayoung1
Please help!!! I have an Amana(Maytag) electric clothes dryer, model #LE7111WM, that suddenly stopped heating during a cycle. The previous load of clothes seemed to dry just fine, but when I opened the door to check on my current load, I noticed it was cool inside the dryer. I then restarted the load, but unfortunately, I have had no heat since. Any advice would be much appreciated. Thank you.
#2 Posted : Thursday, June 10, 2010 3:44:21 AM(UTC)
Replacement parts for AMANA LE7111WM Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/RS3200001.pdf
Unfortunately it does not include wiring diagrams.
Check inside your control console perhaps a wiring diagram is in there or glued to the back panel.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
[COLOR="Blue"]Be careful 240 volts is lethal.[/COLOR]
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 to 12 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Cycling (main) thermostat is on the blower.
Thermal fuse and hi-limit thermostat are on the heater.
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
by jrnutpaul 9/20/2013 8:31:58 AM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 10/8/2011 4:12:13 PM(UTC)
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 5/16/2011 8:58:46 AM(UTC)
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 4/6/2011 6:53:41 AM(UTC)
Help...my dryer stopped heating (Dryer Repair)
by BDGD 12/3/2010 12:47:30 PM(UTC)
by Tcon 10/17/2010 6:22:21 AM(UTC)
by jstayoung1 6/10/2010 12:21:32 AM(UTC)
by atciskanik 3/3/2010 4:32:59 AM(UTC)
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 1/18/2010 5:39:07 AM(UTC)
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 9/5/2009 7:33:29 AM(UTC)
GE Elec stackable dryer stopped heating (Dryer Repair)
by arbiggs 4/21/2009 11:23:47 AM(UTC)
