itwist1
#1 Posted : Thursday, May 27, 2010 5:11:51 AM(UTC)
itwist1
:mad: My washer fills with water but does not agitate. It does nothing. However the cycles advance.Until the drain & spin cycle. It drains without spinning. The motor does not ever sound like its even attempting to turn on. I have checked the ohms on the magnetic lid switch. Ran the diagnostics came back clean on everything. The status indicator light is not on. I have reset the machine using the reset method for both the older machines and the newer machines. Now what? ANYONE?:confused:
applianceman
#2 Posted : Thursday, May 27, 2010 5:38:31 PM(UTC)
applianceman
The motor fuse is most likely blown if the light on the motor isn’t on. The fuse is located on inline the wires on the right hand side of the machine under some tape. There is a picture on this page that shows where the fuse is http://www.appliance-repair-it.com/GE-washer-repair.html
If the fuse isn’t blown or a new fuse doesn’t fix it the motor is bad.
GE Hydrowave Washer Motor Hot Code (Washer Repair)
by Terry B 4/26/2020 11:13:26 AM(UTC)
GE Hydrowave Washer control panel reset? problem (Washer Repair)
by janiew48 3/9/2019 8:34:15 AM(UTC)
GE Hydrowave Washer Help (Washer Repair)
by Ae3734 1/13/2017 7:59:44 AM(UTC)
GE Hydrowave Washer won't spin (Washer Repair)
by Lakelander 10/30/2015 9:47:08 AM(UTC)
GE hydrowave washer on the fritz (Washer Repair)
by Robinwyman 10/7/2015 9:18:51 AM(UTC)
GE Hydrowave washer sagging apron? (Washer Repair)
by Robgeneb 8/17/2015 12:47:42 PM(UTC)
GE Hydrowave washer won't spin or agitate (Washer Repair)
by lilajfischer 8/7/2014 3:20:38 PM(UTC)
Removal of GE Hydrowave washer agitator (Washer Repair)
by Dave Storck 3/30/2014 11:18:01 AM(UTC)
GE Hydrowave Washer won't spin or agitate (Washer Repair)
by budmanluvtofish 1/15/2013 4:02:27 AM(UTC)
GE hydrowave washer wont spin (Washer Repair)
by dgjr 6/19/2012 1:33:10 AM(UTC)
GE Hydrowave washer won't agitate (Washer Repair)
by gaotu49 10/12/2011 8:06:48 AM(UTC)
GE hydrowave washer repair--lesson learned (Washer Repair)
by Narapni 2/22/2011 1:22:54 AM(UTC)
GE Hydrowave washer (Washer Repair)
by richappy 7/31/2009 4:16:21 AM(UTC)
