I have a GE Hydrowave washer that will fill, drain, and spin but will not agitate. I've checked the fuse and lid switch for continuity and both are ok. I do not have a blinking lite on the inverter board. Do all boards on inverter motors have a led lite because I can't locate one on this motor. Can anyone advise me how to check motor.
Sincerely
Vincent
Resetting it doesn't work. I've even changed the control panel. Same results. It fills then switches to wash and just sits there,no sounds coming from the motor. I have another motor but are there any ways to check the motor.
