gaotu49
#1 Posted : Wednesday, October 12, 2011 8:06:48 AM(UTC)
gaotu49
I have a GE Hydrowave washer that will fill, drain, and spin but will not agitate. I've checked the fuse and lid switch for continuity and both are ok. I do not have a blinking lite on the inverter board. Do all boards on inverter motors have a led lite because I can't locate one on this motor. Can anyone advise me how to check motor.
Sincerely
Vincent
mikirk
#2 Posted : Wednesday, October 12, 2011 11:32:50 AM(UTC)
mikirk
Check out my post, see if it helps any.
http://forum.appliancepartspros...r-wont-spin-agitate.html
gaotu49
#3 Posted : Wednesday, October 12, 2011 1:33:22 PM(UTC)
gaotu49
Resetting it doesn't work. I've even changed the control panel. Same results. It fills then switches to wash and just sits there,no sounds coming from the motor. I have another motor but are there any ways to check the motor.
