My two year old side/side unit is no longer cooling. I have unplugged the unit and allow to sit for several hours before trying to restart it. When the unit is plugged back in the compressor and all fan seem to be running properly. The unit seems to blowing cool air out at first, then I come back several hours later, the inside is warm. The compressor is very warm to the touch and never cuts off.
If the compressor is running, then you've probably got a sealed system issue. Either a leak or restricted cap tube.
