dragraceit
#1 Posted : Friday, February 26, 2010 3:55:08 AM(UTC)
dragraceit
direct drive coupler was broken replaced, still makes noise on ageitate
cycle, dissassembled ageitator no broken parts cams all work ok.
seems to go forward fine makes gringing noise in other direction,
knots up clothes around agitator?
any ideas?
please help cant afford to replace at this time
sidfink43
#2 Posted : Friday, February 26, 2010 4:55:55 AM(UTC)
sidfink43
It is very difficult for us to comment intelligently on grinding noises because we need to be there to listen to the type of noise and its source, and we are not there, are we.
Since your clothes are interacting with the agitator, I would start by removing the agitator and tub and checking the drive block. You will need a special spanner wrench to get off a spanner nut and remove the basket.
If this checks out ok I would remove the cabinet, by pass the lid switch and operate the machine to see if the sound is in the pump, motor or transmission.
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
Whirlpool Direct Drive Top Loader, grinding noise on spin start (Washer Repair)
by GRTison 5/1/2022 4:14:53 AM(UTC)
Maytag washer mvwb300wq2 has low grinding noise and won't turn on (Washer Repair)
by mzimmerman72 4/4/2022 2:01:41 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
GE Profile Quiet Power 2 - grinding noise BETWEEN stages? (Dishwasher Repair)
by Guest 8/19/2021 1:53:26 PM(UTC)
Whirlpool washer started making grinding noise (Washer Repair)
by apples99 6/30/2021 3:29:01 PM(UTC)
Grinding noise when running. (Washer Repair)
by Donaldbain007 5/30/2021 1:13:54 PM(UTC)
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 5/29/2021 2:00:00 PM(UTC)
Whirlpool Cabrio MVWC400XW making horrible high pitched grinding noise (Washer Repair)
by kwale 3/6/2021 1:11:38 PM(UTC)
Maytag front-load grinding noise... (Washer Repair)
by freq_out 6/29/2020 9:58:07 PM(UTC)
Amana washer makes grinding noise when running (Washer Repair)
by Bruce Congioloso 5/14/2020 11:44:16 AM(UTC)
Kenmore Waser Grinding noise (Washer Repair)
by modsolution 2/14/2020 2:32:03 PM(UTC)
amana washer, grinding noise (Washer Repair)
by oilspotnm 8/11/2018 10:04:08 AM(UTC)
Grinding Noise at End of Spin Cycle (Duet Frontload) (Washer Repair)
by brianinseattle 4/11/2018 11:31:36 PM(UTC)
