TimMaster
#1 Posted : Wednesday, February 17, 2010 11:59:13 AM(UTC)
TimMaster
Refrig had buzzing noise, we unplug the unit ,then plugged it back in, this helped for awhile, then the buzzing was back replaced the overload relay or start relay this helped for a couple of weeks. The buzzing was back again we replaced the capacitor, this help very little. We check the freezer coils and they had ice on them, we defosted and nothing changed. Could it be the thermostat or something to do with the defrost unit and how can we tech it. I have worked on spas for over 30 years have some experience.
magician59
#2 Posted : Wednesday, February 17, 2010 12:28:20 PM(UTC)
magician59
Check the back of the refrigerator at the drip pan to see if any of the refrigerant lines comes into contact with it. If there is even the slighest contact, the unit will buzz all the time the compressor runs. It gets worse if the unit is slightly off level. Don't try to force any of the copper lines away from the pan, but find a suitable insulating material to cushion between the refrigerant line(s) and the drip pan.
TimMaster
#3 Posted : Wednesday, February 17, 2010 12:37:10 PM(UTC)
TimMaster
Not the problem!
alisonarod
#4 Posted : Thursday, February 18, 2010 9:28:41 AM(UTC)
alisonarod
It's going to be your compressor. Check the compressor for continuity. It sounds as if the compressor is dying. Is the food staying cold in the refrigerator or is it warm? You can also check the evaporator fan as well as the thermostat before you give up, but it sounds like a compressor problem to me:(
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer makes buzzing noise with timer dial turned and door closed (Dryer Repair)
by Cuhcs13 2/7/2018 5:43:42 PM(UTC)
Buzzing Noise and Not Working (Microwave Repair)
by intellaprint 12/30/2017 5:20:05 PM(UTC)
"Sensing" buzzing noise (Washer Repair)
by smkelley 4/24/2015 1:51:07 PM(UTC)
Washer buzzing noise (Washer Repair)
by nicker10 4/11/2015 1:57:04 PM(UTC)
Dryer making buzzing noise when pushing timer/start button to start dryer? (Dryer Repair)
by spunkie269 12/2/2014 12:27:00 PM(UTC)
Refrigerator making loud buzzing noise (Refrigerator & Freezer Repair)
by aptone 8/20/2014 9:54:17 PM(UTC)
Washing machine gives a buzzing noise when you try and spin or agitate (Washer Repair)
by spunkie269 3/26/2014 2:17:57 PM(UTC)
Buzzing noise during wash cycle (Dishwasher Repair)
by Geochurchi 2/23/2014 8:14:26 AM(UTC)
Maytag refrig making buzzing noise (Refrigerator & Freezer Repair)
by howieb1950@yahoo.com 7/26/2013 1:13:07 PM(UTC)
Micro Wave working but makes loud buzzing noise sometimes (Microwave Repair)
by mark kuhn 2/10/2013 3:47:56 PM(UTC)
Humming/buzzing noise (Oven Repair (including Ranges and Cooktops))
by AODonovan 1/27/2013 10:21:08 PM(UTC)
Loud buzzing noise and not cooking food (Microwave Repair)
by mattpghpa 9/30/2012 9:01:38 PM(UTC)
Maytag refrigerator buzzing noise (Refrigerator & Freezer Repair)
by drgrid 9/19/2012 12:55:14 PM(UTC)
Loud Buzzing noise coming from Overload Relay (Refrigerator & Freezer Repair)
by buddha131 5/17/2012 6:29:32 AM(UTC)
