13 Pages«<34567>»
adam60351
#41 Posted : Tuesday, February 16, 2010 3:26:59 PM(UTC)
adam60351
Hi Gene, I don't know if I'm testing the motor correctly: directions say to test from service panel on motor plug...is the motor plug on the motor itself? Should the washer itself be plugged in when I test for the ohms?
#42 Posted : Tuesday, February 16, 2010 7:57:14 PM(UTC)
Originally Posted by: yiming Go to Quoted Post
Same problem as before. On startup, I set the model to 01 then tried "t10" and "t11". It doesn't spin at all. Also tried "rinse/spin" cycle with no spinning observed at the "spin" cycle, only a couple of slow back and forth spinning at the beginning.
One difference with the new control board is no "t14" available in the test mode. It goes up to "t13".
Did you program the new control board as described on the first page of this thread?
#43 Posted : Tuesday, February 16, 2010 8:02:30 PM(UTC)
The motor plug is the part of the motor where the wire harness plugs in. The power must be always disconnected prior to continuity test.
yiming
#44 Posted : Wednesday, February 17, 2010 7:40:09 AM(UTC)
yiming
Yes, I did. I entered 01 for the model id first time the new control board was powered on and reprogramed again according to the first page. I didn't try with different model ids this time with the new control board. Should I try other ids, e.g. 02, 03, 04, etc?
#45 Posted : Wednesday, February 17, 2010 11:02:15 AM(UTC)
I'm afraid you did something wrong during the inverter tests. Carefully read the instructions and redo the tests.
yiming
#46 Posted : Monday, February 22, 2010 6:16:11 PM(UTC)
yiming
I went back to the inverter test and measured the voltage between the blue and red wires according to your instruction. The voltage is always present as soon as I enter the test mode, which is not expected per your instruction. The spin tests, t10, t11, have the same result, i.e. no spin, while the voltage is present. Also redid motor and sensor ohm tests seemed normal.
Not sure if the inverter is the problem at the point.
#47 Posted : Tuesday, February 23, 2010 2:26:46 PM(UTC)
Your previous report posted on 1/29/10 says: "There is no voltage measured from these two wires". That's why I recommended to replace the control board.
Your last report says: "...I went back to the inverter test and measured the voltage between the blue and red wires...The voltage is always present as soon as I enter the test mode...". Such result leads to the bad inverter conclusion as it says in the troubleshooting instructions attached to the reply posted on the second page of this thread on 1/28/10: "If 120 VAC is present at the AC input harness and motor resistance is correct, replace the inverter."
Keeping in mind that there is already the new control board and both previous motor tests did not show anything wrong, the problem is a bad inverter.
- The inverter Part number: AP4421584
yiming
#48 Posted : Tuesday, February 23, 2010 4:33:37 PM(UTC)
yiming
Thanks Gene. I will try replacing the inverter. Will let you know how it goes.
yiming
#49 Posted : Monday, March 1, 2010 7:25:22 AM(UTC)
yiming
Yes, the new inverter fix the problem. Gene, thanks a million for your help along the way. It's been a rewarding process. --Yiming
#50 Posted : Tuesday, March 2, 2010 6:26:39 PM(UTC)
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
Guest (13)
ge front load washer won't tumble/spin (Washer Repair)
by Laeloni 3/26/2011 10:07:27 AM(UTC)
13 Pages«<34567>»
