Raljac63
#1 Posted : Wednesday, February 10, 2010 7:15:09 AM(UTC)
Raljac63
My electric dryer has no heat, I have done the follwoing:
1. replaced element
2. Checked voltage at plug got 220 volt, checked voltage at terminal strip L1&L2 got 110
2. did a continunity check on thermal fuse, thermal cutoff, operating thermostat and hi limit therostat
3. Then I jumper each of the above and the element still does not heat.
4. When I check for voltage across the heating element terminal connections while the unit is running I get zero (O) voltage.
What esle can I check? Is it a bad timer? Is there a way to bypass the time to see if it is the bad component?
Ralph
#2 Posted : Thursday, February 11, 2010 5:13:57 PM(UTC)
Replacement parts for WHIRLPOOL REX5634KQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406688.pdf
[COLOR="Blue"]My electric dryer has no heat, I have done the follwoing:
1. replaced element
2. Checked voltage at plug got 220 volt, checked voltage at terminal strip L1&L2 got 110[/COLOR]
Did you get 220 at the terminal strip. I imagine the you were measuring from Neutral to L1 and L2. The problem with this is that if one side of the line is missing (bad line cord etc.), the 110 can feed through other components so you will see it on both sides but it is the same phase so no 220.
[COLOR="Blue"]2. did a continunity check on thermal fuse, thermal cutoff, operating thermostat and hi limit therostat
What esle can I check? Is it a bad timer? Is there a way to bypass the time to see if it is the bad component?[/COLOR]
I do not know why you are jumping thermostats when it sounds like you have a meter re: measuring the voltage.
Why not just use ohms.
Unplug the unit, set it to timed dry mid-cycle and measure the timer contacts.
System Wiring Check
Confirm that you have 220 at the terminal strip.
If OK
Unplug the unit
Attach/tape one lead of your meter to L1, leave it there.
Set the timer to timed dry, mid cycle.
Then just work your way back through the heating components.
All should be 0 ohms till you get to the heat coil and then 10 ohms approximately on it's far side.
If you make it all the way back to the far side of the heater and all is OK, then either you have a wire burned off, a bad connection, the heat centrifugal switch on the motor is not being closed or the switches contacts are toast.
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Maytag Centennial dryer will not heat up (Dryer Repair)
by 1hkfan 10/31/2012 6:51:34 PM(UTC)
Dryer will not Heat up (Dryer Repair)
by jasmineblue27 8/19/2012 12:56:43 PM(UTC)
Dryer will not heat up consistently (Dryer Repair)
by GPDIY 1/4/2012 5:21:02 AM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by ray2 5/13/2011 7:10:58 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
Dryer will not heat up? (Dryer Repair)
by mel1293 10/3/2009 12:06:09 PM(UTC)
by Steve T 7/9/2009 7:32:03 AM(UTC)
by clemmy 5/19/2009 7:19:42 AM(UTC)
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong (Dryer Repair)
by Seeking Help 1/11/2009 3:04:44 PM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
Whirlpoool dryer will not heat up (Dryer Repair)
by ayellis 4/16/2008 6:47:04 AM(UTC)
