Tim1539
#1 Posted : 17 years ago
Tim1539
My dishwasher is make a very loud noise when it starts the wash cycle. Water comes out of the arm but not enough to wash anything. I have taken the motor with pump off and cleaned everything from inside the dishwasher to the pump. I believe the pump is bad but I'm not sure. I see where there is a impeller repair kit but I don't see how to take it apart.
Can this be replaced with a new pump?
And how do you get the old pump off?
Waiting with alot of dirty dishes:)
#2 Posted : 17 years ago
Hi Tim,
GE does not sell the pump separate. It comes as an assembly (pump & motor).
The impeller repair kit comes with the complete installation instructions and if the old motor is not damaged - you probably do not need the whole assembly.
- The part number for the impeller repair kit is AP631386
- The part number for the pump & motor assembly is AP3192237
Tim1539
#3 Posted : 17 years ago
Tim1539
How do you get the impeller off?
#4 Posted : 17 years ago
As I said it comes with the complete instructions.
Tim1539
#5 Posted : 17 years ago
Tim1539
I will order now. It's just I have everything apart and it's driving me nuts not being able to take the impeller off the motor.
#6 Posted : 17 years ago
Unscrew the chopper, holding the motor shaft with a pliers.
Unscrew the plastic ring (CW).
Unscrew the impeller, holding the motor shaft with a pliers.
Remove the screws holding the pump to the motor and pull the pump out.
Tim1539
#7 Posted : 17 years ago
Tim1539
Thanks, I will try that tonight. I ordered the part and it will be here in 4 to 5 days
#8 Posted : 17 years ago
Keep me updated, please.
Tim1539
#9 Posted : 17 years ago
Tim1539
I got the new Impeller Assy installed and it works fine. THANKS
P.S. The only thing I had a problem with was the size of writing on the instructions. Very, very small. I'm not 20 anymore. Thank you again:)
#10 Posted : 17 years ago
I'm glad you were able to fix it.
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 3 years ago
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 4 years ago
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 5 years ago
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 6 years ago
GE profile dishwasher (Dishwasher Repair)
by barnee72 9 years ago
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
by cjsrinivas 9 years ago
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 11 years ago
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 11 years ago
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 11 years ago
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11 years ago
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 11 years ago
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 11 years ago
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 12 years ago
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 12 years ago
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 12 years ago
