Tim1539
#1 Posted : Wednesday, March 26, 2008 11:30:33 AM(UTC)
Tim1539
My dishwasher is make a very loud noise when it starts the wash cycle. Water comes out of the arm but not enough to wash anything. I have taken the motor with pump off and cleaned everything from inside the dishwasher to the pump. I believe the pump is bad but I'm not sure. I see where there is a impeller repair kit but I don't see how to take it apart.
Can this be replaced with a new pump?
And how do you get the old pump off?
Waiting with alot of dirty dishes:)
#2 Posted : Wednesday, March 26, 2008 12:24:08 PM(UTC)
Hi Tim,
GE does not sell the pump separate. It comes as an assembly (pump & motor).
The impeller repair kit comes with the complete installation instructions and if the old motor is not damaged - you probably do not need the whole assembly.
- The part number for the impeller repair kit is AP631386
- The part number for the pump & motor assembly is AP3192237
Tim1539
#3 Posted : Wednesday, March 26, 2008 1:40:41 PM(UTC)
Tim1539
How do you get the impeller off?
#4 Posted : Wednesday, March 26, 2008 1:50:11 PM(UTC)
As I said it comes with the complete instructions.
Tim1539
#5 Posted : Wednesday, March 26, 2008 2:23:30 PM(UTC)
Tim1539
I will order now. It's just I have everything apart and it's driving me nuts not being able to take the impeller off the motor.
#6 Posted : Wednesday, March 26, 2008 2:33:54 PM(UTC)
Unscrew the chopper, holding the motor shaft with a pliers.
Unscrew the plastic ring (CW).
Unscrew the impeller, holding the motor shaft with a pliers.
Remove the screws holding the pump to the motor and pull the pump out.
Tim1539
#7 Posted : Wednesday, March 26, 2008 3:12:49 PM(UTC)
Tim1539
Thanks, I will try that tonight. I ordered the part and it will be here in 4 to 5 days
#8 Posted : Wednesday, March 26, 2008 3:17:39 PM(UTC)
Keep me updated, please.
Tim1539
#9 Posted : Wednesday, April 2, 2008 4:32:43 PM(UTC)
Tim1539
I got the new Impeller Assy installed and it works fine. THANKS
P.S. The only thing I had a problem with was the size of writing on the instructions. Very, very small. I'm not 20 anymore. Thank you again:)
#10 Posted : Wednesday, April 2, 2008 5:40:59 PM(UTC)
I'm glad you were able to fix it.
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 2/7/2022 7:19:40 PM(UTC)
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 12/15/2020 8:18:18 AM(UTC)
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 3/26/2020 11:32:29 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
GE profile dishwasher (Dishwasher Repair)
by barnee72 1/14/2016 5:47:55 PM(UTC)
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
by cjsrinivas 12/21/2015 8:06:27 PM(UTC)
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 3/1/2014 5:22:20 AM(UTC)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 1/11/2014 10:15:13 AM(UTC)
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11/4/2013 8:17:53 AM(UTC)
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 9/19/2013 5:45:58 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 1/25/2013 9:49:05 AM(UTC)
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 1/6/2013 6:30:22 PM(UTC)
