wildcatgs
#1 Posted : Monday, February 8, 2010 7:28:05 AM(UTC)
wildcatgs
just got this ge refrig used and the water dispenser works fine but no water to the ice maker. found out that the motor for the tray to crush or dispense ice is bad. when you press on door switch you hear it try to turn but its locked up tight. would this stop water from coming into the ice tray? when i turn on the ice maker it has power but never fills with water.
#2 Posted : Monday, February 8, 2010 10:53:49 AM(UTC)
Does the ice maker have a green LED light? If it does, then does it stay on or it's blinking?
Remove the ice bucket and check if the auger motor will work without it.
If it would not, remove the motor and try to defrost it. Sometime it can be just frozen.
Here are the breakdown diagrams and Replacement parts for General Electric GSS22KGPHBB Refrigerator | AppliancePartsPros.com
wildcatgs
#3 Posted : Monday, February 8, 2010 2:48:49 PM(UTC)
wildcatgs
yes the light is green solid no blinking the motor is toasted took it out and its rusted stuck so ordered new one. would that stop the water from going to the ice disp or could it be the valve? i do have water coming to the door disp with no problem and put new filter in.
#4 Posted : Tuesday, February 9, 2010 12:04:39 PM(UTC)
If the water feeding tube into the ice maker is not obstructed, then the problem most likely is a bad water inlet valve on the back of the refrigerator.
- The water valve Part number: AP3192626
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Frige 2014 no Ice & frige is 50 degrees (Refrigerator & Freezer Repair)
by Plus160 7/5/2023 5:05:07 PM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
GE Cafe Refrigerator No Ice (Refrigerator & Freezer Repair)
by amappliancewi 2/8/2023 5:22:22 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
No Icecream at night - Freezer stops cooling around 8PM and everything is Frozen by 8AM. - (Refrigerator & Freezer Repair)
by usercraig 3/7/2022 7:40:11 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
Samsung RS265TDRS Not Cooling/No Ice (Refrigerator & Freezer Repair)
by Guest 5/31/2021 10:09:58 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
** RESOLVED ** Subzero 590, no ice (Refrigerator & Freezer Repair)
by Intel1919 9/12/2020 9:54:24 AM(UTC)
