wee mac
#1 Posted : Monday, August 27, 2007 6:00:17 AM(UTC)
wee mac
Freezer Is Blowing Cold Air But Not Enough To Freeze Food. Setting Is At Max.
Any Suggestions
Thanks Wee Mac
#2 Posted : Monday, August 27, 2007 9:44:54 AM(UTC)
Hi wee mac
The first thing I would check is condition of the condenser coil. If it's blocked with lint, the compressor will overheat and would not perform properly. In most cases cleaning could help to eliminate the problem. Remove the front and the rear panels and clean the condenser coil from any lint and dust. Wait about 24 hours to see if it works.
If this is not an issue then the cooling system could be low on Freon or the compressor has low capacity. To fix it you have to call a certified technician and it is going to be pretty expensive.
If your fridge is very old it is probably not efficient and it's not worth to fix it. It is possible your local utility company has a reimbursement program to utilize such old refrigerator.
- For the future references here are the break down diagrams for the Kitchen Aid refrigerator Model KBRS22KGWH0
Good luck.
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 9/24/2015 9:57:47 AM(UTC)
by billpulsipher@gmail.com 8/28/2015 11:25:19 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 8/6/2015 2:05:17 PM(UTC)
by Suzalasue 5/28/2015 6:08:45 AM(UTC)
by wnorton 1/27/2015 3:21:20 PM(UTC)
