dick2256@hotmail.com
#1 Posted : Wednesday, March 26, 2008 7:43:34 AM(UTC)
has a plastic lint ring on the inside of the tub up at top
is it possible to remove this so it can be cleaned?
All of the dirk clothes come out with a chalky smear all over them
#2 Posted : Wednesday, March 26, 2008 3:12:18 PM(UTC)
I would recommend to use the Washer Magic cleaner instead of taking the washer apart. It works very good (I used it at home) and if you will use it periodically, your clothes will always smell fresh.
Speed Queen Washer makes random squeaking noise (Washer Repair)
by Guest 2/10/2024 7:29:00 AM(UTC)
Speed Queen washer problem (Washer Repair)
by Guest 7/21/2023 1:04:45 PM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
Speed Queen Washer Spin Cycle (Washer Repair)
by phaffy12 7/21/2022 6:23:17 AM(UTC)
Speed Queen washer sounds like a whale (Washer Repair)
by Guest 5/2/2021 6:07:40 PM(UTC)
Speed Queen washer not filling (Washer Repair)
by CraigRich 4/7/2020 1:39:07 PM(UTC)
Speed Queen washer transmission repair (Washer Repair)
by thorning 4/2/2018 11:07:15 AM(UTC)
Black spots on Speed Queen Washer (Washer Repair)
by dave0702 1/23/2011 2:39:00 PM(UTC)
Speed Queen washer (Washer Repair)
by Dave Spearing 9/24/2010 9:53:20 AM(UTC)
Speed Queen Washer Dumps A Little Water on Agitation (Washer Repair)
by LarryRt 1/9/2010 2:00:19 PM(UTC)
Speed Queen washer leaks during spin cycle (Washer Repair)
by LeakyWasher 5/4/2009 6:11:41 PM(UTC)
Amana Speed Queen Washer (Washer Repair)
by tonee74 4/14/2009 7:25:21 AM(UTC)
Speed Queen washer is out of balance (Washer Repair)
by Mark Mac 11/18/2008 2:06:39 PM(UTC)
by kovall 11/13/2008 2:20:56 PM(UTC)
Speed Queen Washer will spin not Drain? (Washer Repair)
by Joshua 2/6/2008 1:45:58 PM(UTC)
