bill52387
#1 Posted : Tuesday, January 26, 2010 4:58:09 AM(UTC)
bill52387
this is an electric dryer ,whirlpool that does not heat up.
i replaced the heating element but it did not solve the problem,please help!!!
#2 Posted : Wednesday, January 27, 2010 3:59:18 AM(UTC)
Replacement parts for WHIRLPOOL LEC6848AN1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203398692.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
No heat in dryer (Dryer Repair)
by davehriver 11/23/2011 11:01:51 AM(UTC)
by jgg35019 11/1/2011 5:28:41 PM(UTC)
NO HEAT in Dryer (Dryer Repair)
by McCarty 8/1/2011 3:08:26 PM(UTC)
no heat in dryer (Dryer Repair)
by trillo 2/9/2011 1:46:38 PM(UTC)
by lucky915 1/11/2011 12:53:24 PM(UTC)
No Heat in Dryer (Dryer Repair)
by Don Vogler 8/4/2010 5:31:09 PM(UTC)
by staschu 1/16/2010 3:31:45 AM(UTC)
Whirlpool Dryer Has no Heat in Dryer (Dryer Repair)
by jsanabia 6/8/2009 2:35:54 PM(UTC)
