washer leaks water from tub above the transmission
Hi, I'm having the same problem with my Maytag (PAV3300AWW), undecisive on which part to purchase for the problem. Please help. Need part number. Originally Posted by: Gene
Hi Ricardo,
What exactly is wrong with your washer?
Post it as a new thread, please.
In rinse cycle, tub collects water fine, turns really slow, and visual leak between tub and top part of what I believe to be the transmission. I'm understanding that the part that I need for this is tub and seal kit # 35-2974. Is this correct?:confused: Originally Posted by: Gene Hi Ricardo,
In order to fix this leak you have to replace the tub and seal kit. The kit comes with the complete instructions and to do the job right you need a few special tools. - The part number for the tub and seal kit is AP3875413 - The part number for the spring removal tool is AP3854720 - The part number for the seal nut is AP3873487 - The part number for the spanner wrench is AP3854730 Here are the break down diagrams for the Maytag washer Model PAV3300AWWGene.
Hi Gene, it's me again, I apologize for bothering so much. Would you know the part number for the ball bearings of the transmission of a Frigidaire Model #FWX833ASO? I'm assuming it's within the two seals. Please correct me if I'm wrong. Originally Posted by: Gene
Hi Ricardo.
As far as I know Frigidaire does not sell any transmission parts separate.
can one of you guys give me a bit of advice in order to take it appart. I am mechanically inclined but I can't figure out how to take the tub out ...
thanks a lot !
hybrid999,
What is the complete model number of the washer?
