2 Pages<12
fullmetalshovel
#11 Posted : Saturday, January 16, 2010 3:43:15 AM(UTC)
fullmetalshovel
Still trying to find the problem, bobski. Have not replaced any parts, yet. The board for this unit costs about $160, so I am going to try denman's new reccomendations (thank you) before replacing. I will respond when I figure it out.
fullmetalshovel
#12 Posted : Saturday, January 16, 2010 6:49:46 AM(UTC)
fullmetalshovel
Denman,
I believe it is the board.
But, just to confirm before I place the order:
Retested thermistor and moisture sensor and both passed.
This time when I tested the moisture sensor pins on the board, I pulled the board completely out, unplugging all the connections to the board itself. When I performed the tests yesterday, I had just unplugged the machine from the wall, and the appropriate wiring harness on the board.
Yesterday's test results on the 2000k=1.875
Today's test results on the 2000k setting=675
Is that big of a variation possible?
675 would constitute a resistance of <1 m-ohms, correct??
Also, when it rains it pours. On my Whirlpool Duet Washer (GHW9100LW) I have noticed water streaks on the front of the machine under the door. I assume this is the door seal. If so, is installing a new seal easy?
#13 Posted : Saturday, January 16, 2010 9:42:43 AM(UTC)
[COLOR="Blue"]Is that big of a variation possible[/COLOR]?
Has to be you read it so something is causing it.
Although they do not mention it the polarity of the meter leads may make a difference. I would check it both ways re: red lead on one test point and then the black lead on that test point.
[COLOR="Blue"]
675 would constitute a resistance of <1 m-ohms, correct??[/COLOR]
Yes it is less than one meg-ohm.
Perhaps try cleaning this area with ispropyl alcohol available at drug stores or an electronics contacts cleaner (non-residue type) and a toothbrush (be gentle). Do not reconnect till all the solvent has evaporated.
[COLOR="Blue"]Also, when it rains it pours. On my Whirlpool Duet Washer (GHW9100LW)[/COLOR]
I would start a new thread in the Washer Section to get info on this
Also do an advanced search "duet door seal" with the washer secxtion chosen.
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
Whirlpool duet dryer (Dryer Repair)
by norbreym28 7/16/2016 8:29:04 AM(UTC)
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
2 Pages<12
