Still trying to find the problem, bobski. Have not replaced any parts, yet. The board for this unit costs about $160, so I am going to try denman's new reccomendations (thank you) before replacing. I will respond when I figure it out.
Denman, I believe it is the board. But, just to confirm before I place the order: Retested thermistor and moisture sensor and both passed. This time when I tested the moisture sensor pins on the board, I pulled the board completely out, unplugging all the connections to the board itself. When I performed the tests yesterday, I had just unplugged the machine from the wall, and the appropriate wiring harness on the board. Yesterday's test results on the 2000k=1.875 Today's test results on the 2000k setting=675 Is that big of a variation possible? 675 would constitute a resistance of <1 m-ohms, correct??
Also, when it rains it pours. On my Whirlpool Duet Washer (GHW9100LW) I have noticed water streaks on the front of the machine under the door. I assume this is the door seal. If so, is installing a new seal easy?
[COLOR="Blue"]Is that big of a variation possible[/COLOR]? Has to be you read it so something is causing it. Although they do not mention it the polarity of the meter leads may make a difference. I would check it both ways re: red lead on one test point and then the black lead on that test point. [COLOR="Blue"] 675 would constitute a resistance of <1 m-ohms, correct??[/COLOR] Yes it is less than one meg-ohm. Perhaps try cleaning this area with ispropyl alcohol available at drug stores or an electronics contacts cleaner (non-residue type) and a toothbrush (be gentle). Do not reconnect till all the solvent has evaporated.
[COLOR="Blue"]Also, when it rains it pours. On my Whirlpool Duet Washer (GHW9100LW)[/COLOR] I would start a new thread in the Washer Section to get info on this Also do an advanced search "duet door seal" with the washer secxtion chosen. |
THIS FORUM IS DEAD!!!!!!! |
