mopsgt
#1 Posted : Monday, March 10, 2008 5:32:59 PM(UTC)
mopsgt
My 2 year old Whirlpool electric dryer runs fine but when the timer gets to the end of the cycle it does not shut off. I replaced the timer and the problem is the same. I can manually advance the timer to the end of the cycle and the buzzer sounds and the dryer shuts off, but it will not do it on its own. otherwise the dryer runs fine. Any suggestions?
#2 Posted : Tuesday, March 11, 2008 1:20:17 PM(UTC)
It did not stop on both, the timed dry and the auto dry, or on the auto dry only?
mopsgt
#3 Posted : Wednesday, March 12, 2008 12:15:34 PM(UTC)
mopsgt
Gene,
Thanks for your help. The dryer doesn't shut off on both the timed cycle and the auto-dry cycles. It just keeps running at the end of the cycle, but can be manually advanced and will shut off.
#4 Posted : Wednesday, March 12, 2008 1:50:35 PM(UTC)
Remove the vent hose from the back of the dryer and run one or two loads. See if it'll shut off.
Check if 120V is coming to the timer motor (terminals TM & BK) when the timer will advance and when it will stuck. Do not forget to remove one of the timer motor wires before testing.
Post your findings.
mopsgt
#5 Posted : Wednesday, March 12, 2008 2:27:43 PM(UTC)
mopsgt
Gene,
The dryer in question is actually at a friends house who's husband just passed away. I'm trying to help fix up a few neglected issues at the hiouse.
When she first told me about the dryer problem I saw that the dryer vent hose was not even connected to the back of the dryer. I connected it at that time, so I don't think that is the problem.
I will check the voltage thursday some time, I work midnight-8am and try to stop there when I can.
Thanks again for your help, I am handy, but haven't done many appliance repairs.
#6 Posted : Wednesday, March 12, 2008 2:59:00 PM(UTC)
Might be this wiring diagram will help you to diagnose the problem.
Guest (4)
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 6/8/2022 5:45:29 AM(UTC)
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 9/26/2018 9:11:22 AM(UTC)
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 10/8/2017 9:57:09 AM(UTC)
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 3/21/2015 9:53:19 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
whirlpool electric dryer (Dryer Repair)
by ajlgap19 6/6/2014 9:55:32 AM(UTC)
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 1/23/2014 7:03:27 PM(UTC)
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 1/16/2014 9:02:04 AM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
by eisehunter 5/28/2013 1:44:53 PM(UTC)
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 2/6/2013 12:59:47 PM(UTC)
Whirlpool Electric Dryer (Dryer Repair)
by mayork 11/14/2012 10:21:04 AM(UTC)
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 9/10/2012 2:08:11 PM(UTC)
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 8/20/2012 12:48:36 PM(UTC)
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 8/18/2012 1:10:17 PM(UTC)
